When registering, please note that you will not be able to change your username. It is also very important that you read and understand the Forum Rules & Terms of Use before signing up.
Renewable Heating Hub Forums
Well & Truly Off The Grid
Buy & Sell
- 25 Forums
- 1,442 Topics
- 30.2 K Posts
- 32 Online
- 1,225 Members
Yes, it is one of those two who first alerted me to the...
By IvanOpinion , 4 hours ago
RE: EV charger installation question – I don't want to bury the cable
The fact that the MCB is rated 16A tells us what we nee...
By Transparent , 5 hours ago
RE: Are You Getting the Most Out of Your Renewable Energy?
Thanks, @editor. Ideally it’d be someone who would li...
By Majordennisbloodnok , 7 hours ago
Unless adequately controlled it could devour your bank ...
By Derek M , 7 hours ago
RE: Effect of buffer tank or volumiser on heat pump system
I think that you will find that the best location for a...
RE: ASHP Commissioning: What Questions Should I Ask the Installer?
@derek-m thanks - will look out for the point regarding...
By Declan90 , 1 day ago
RE: Noise problems with newly installed Samsung 8kW ASHP
@editor @kenbone Thanks, I would be very interested ...
By Elton , 1 day ago
This is all a bit too frequentist for my liking. The pr...
By scrchngwsl , 1 day ago
Relax with 4K drone footage of lawn mowing to a smooth Motown tune
Sending out some chilled weekend vibes to everyone. Lis...
RE: Incorrect Billing of Customers with a Smart Meter
The starting point of that discussion on Camelot-Forum ...
Share Your Experiences with Heat Pump Manufacturer Support
Have you ever reached out to your air source heat pump ...
RE: Is this a bad installation and is there something wrong with my Samsung heat pump?
@ant87 thanks for that.
By David999 , 2 days ago
I might change my mind again, but I'm currently unlikel...
By IvanOpinion , 3 days ago
RE: Samsung ASHP scheduling help
@elgreco69 worth reading the GitHub here as that will a...
By morh , 3 days ago
RE: ASHP sizing - value of Heat Transfer Coefficient
@toodles Thanks for the explanation I get it now as I h...
By Jancold , 3 days ago
RE: Questions about yearly heat pump maintenance
For the installer, I believe servicing and maintenance ...
@retrorich It is very worrying that any of this should ...
RE: Spacing for roof fixing bolts ?
There is another consideration...but alas this doesn't ...
RE: Air source heat pumps and noise
Yes, but when they go wrong things get really sticky. D...
Heat Pump Humour
Latest Topics
By David999 3 hours ago
By heat-pump-newbie 6 days ago
By jamesw 6 days ago
By KoRWraith 1 week ago
Home energy storage & battery register
By Mars 1 week ago
