'Chinese Diesel Heater' to heat the home .....
Last year i installed a chinese diesel heater to heat/pre heat my kitchen/conservatory area. it was much better than i expected, being able to control it via the remote made it simple to operate - i could even turn it on from bed when i woke up so the kitchen/conservatory was warm when we got up.
ok, for those who may be thinking exhaust fumes, dangers of catching fire etc .... the heater itself was sited outside and the hot air was fed into our house, under the kitchen units. Initially i had the air intake taking air from the outside, but soon realised i actually needed to take the air intake from INSIDE the house, so installed another ducting run, again under the kitchen units. i also had to use a step down transformer from 240v to 12v DC but as its all under the kitchen units its tucked nicely out of sight.
ive installed the ducting in such a way that the heater can be removed from the patio area when not required and the ducting 'sealed' using end caps.
i 'acquired' a cover for it all so its protected a bit from the elements - its not pretty but it works. it wouldn't take too much to make a permanent enclosure should i ever feel the need. i like the temp enclosure because i can remove it all when the heater isn't needed to boost the temperature up. the temp enclosure also helps in insulating the ducts, i kept the external ducting runs to a minimum so as to reduce heat loss.
Running cost was around a litre of fuel every other day, depending on length of time and of course temp settings, but as a rough guide we used around 5 litres every two or three days for 12 hours running.
Our only other source of heating in that area is an inverter (air con/heating) so the diesel heater took some of the 'strain'
I will definitely be using it again this coming winter, though i may look at installing a bigger fuel tank somehow, prob using a 20 litre paraffin container, so i will only need to fill it up once a week! i use metal jerry cans to get the diesel from the local garage, though i really should look at cheaper fuels such as heating oil or paraffin, but dont know if they would impact on the heater itself, i prob need to check out youtube to see if anyone has used alternative and cheaper fuels (so long as theyre easily obtainable for me!)
if i ever get round to tweaking the system, i will look at ways to recover the heat wasted through the exhaust, which really gets hot. i have seen a few methods on you tube which look simple enough, very 'Heath Robinson', but i like that approach !!
The heater has now been reinstalled (with a cover over the top of it all). Its started up without a problem, i was expecting a few teething issues, but so far ......
still need to look into a different fuel though, but it really does make a difference - probably going to split the heating pipe into two, using a y piece or t piece, so that i can run a heater outlet into an adjacent downstairs shower room/wc. would really love to sit down and design one for the 3d printer to produce an 'unequal tee' on tinkercad ...
quick update, i bought a t piece and additionl trunking from ebay, cheap enough to not even start designing a 3d printed one! the diesel heater has been working throughout the winter (starting to get a bit warmer now) and i bouhgt one of these, to transfer the fuel from a 20L plastic drum
works really well, the nozzle doesnt fit into a jerry can , but works brilliantly with the 20L plastic drum. no spills, no diesel wasted, no diesel on your hands etc and really is easy to transfer fuel now.
i suppose the ideal will be just to put the feed pipe into the container itself and let it pump the fuel direct to the burner. i might have a go at that when i get chance, but for now the diesel heater really is a very good addition/boost for the existing (or only just existing) heating options in the kitchen.dining/conservatory where we live most of the day.
- 2,378 Topics
- 53.9 K Posts
- 150 Online
- 6,060 Members
RE: Grant ASHP 17.5 kw. weather curve
Firstly welcome to the forums. I hope you ar...
By JamesPa , 8 hours ago
@toodles We had a reroof concurrently with the PV in...
By Papahuhu , 8 hours ago
RE: Cascade 2x Grant Areona 10kw ASHP - Ongoing setup issues
(Almost) all heat pumps do defrost by taking heat from ...
By JamesPa , 9 hours ago
The Great British Heat Pump Owner Persona Survey: Let's Build Our Archetype!
Happy New Year everyone! As we head into 2026, ...
By Mars , 9 hours ago
Seems to be the only logical explanation. Our ASHP was ...
By benson , 11 hours ago
@jamespa thanks, yes it seemed mad to me. An exert f...
By Papahuhu , 11 hours ago
RE: Optimum new build house design for Heat Pump
From first principles I would say: Definitel...
By JamesPa , 12 hours ago
As good a place as any to drop this video:/p>
By Mars , 16 hours ago
@transparent D'Oh - I did look before I posted but I mi...
By dr_dongle , 17 hours ago
Compatibility with Samsung AE080RXYDEH
I am new to all this. We have a SamsungAE080RXYDEH that...
By John999 , 17 hours ago
@batpred Maybe you should buy your additional batter...
By Bash , 19 hours ago
RE: Data Accuracy Problem: Daikin 8kW Heat Pump's Onecta App vs MMI Power Consumption
@nursethescreens Yes, comfort and happiness of the fami...
By Toodles , 20 hours ago
Thanks folks. I had tried googling an ethernet lab adap...
By z8lccda , 1 day ago
RE: Changing from 4-port buffer to volumizer
@toodles I'm not concerned that the behaviour is not no...
By Andy1618 , 1 day ago
I agree, and I think there are two things in play here....
RE: Water Hammer After Heat Pump Install
That's really helpful. Yor last sentence confirms it'...
RE: Help needed with Grant Aerona 3 issues
First time posting so bear with me. Some bits that have...
By Adamp , 3 days ago
RE: Mitsu PUHZ-SW120YHA + EHSC-VM20Uk - Performance
All understood. Obviously its a bit house de...
