Refrigerant R32, is it now banned in the EU from 1st Jan 2027 for monobloc ASHPs?
Not that long ago R32 was touted as the 'refrigerant of the future' - a pure compound low GWP (675) HFC with near identical performance properties to the then popular but much higher GWP R410A.
Now it seems R32 will shortly be consigned to history in the EU under the newly adopted legislation EC2024/573 targeting the drawn-down and phase out of greenhouse gas use. The UK is not obliged to follow the EUs legislative timeline. Refrigeration industry leaders in the UK are calling for a more cautious and measured draw down and phase out.
For once, that's not the UK shying away from Net Zero 2050 or simple anti EU rhetoric - rather a genuine concern that EU legislation is often driven ideologically rather than pragmatically, enacting legislation that could jeapordise the refrigeration industry. The proposed EU ban on PFASs (so-called 'forever chemicals') is a case-in-point. That would ban most common HFO synthetic refrigerants used in the heat pump industry, including R1234yf and R1234ze and whole host of other ASHRAE refrigerants developed as ultra low GWP alternatives to HFC refrigerants. These are commonly used in larger industrial heat pumps where A2L and A3 flammable category refrigerants such as R32 and R290 cannot be used for safety reasons.
R290 propane will probably be the future long-term refrigerant for small hermetic monobloc ASHPs, but ASHP manufacturers such as Ideal Logic Air, Ebac and others have all recently punted for R32 in newly launched domestic market products. This could be a very unwelcome development for them...
This has been delayed from what I believe to be this year originally. Doesn't affect anything at present until the cut off date and even then it makes little difference to most customers. R290 has some serious siting restrictions so will in many cases prevent a heat pump purchase.
Thanks for the clarification. Sounds like the 2027 date is the key milestone, so for now R32 installations can continue as normal. Definitely interesting to see how the industry will adapt with R290’s limitations for some sites.
Posted by: @dgclimatecontrolThis has been delayed from what I believe to be this year originally. Doesn't affect anything at present until the cut off date and even then it makes little difference to most customers. R290 has some serious siting restrictions so will in many cases prevent a heat pump purchase.
I wonder if heat pump manufacturers will tone these siting restrictions down. I suspect so. They aren't, so far as I have been able to establish, actually enshrined in any regulation (at least not in the UK) in which case its is within their gift to amend them!
They might also add a diagram showing explicitly that a heat pump directly under an opening window is OK, provided that the top of the case is below the opening part. Currently only some of the diagrams that manufacturers draw make that clear, although I am not aware of any which clearly exclude heat pumps below windows, so for me at least the intended interpretation is not in doubt (and makes sense given that propane is heavier than air).
On the other hand the EU regulation as reproduced above would allow R32 if safety requirements prohibit R290, so maybe R32 will remain as a fall back at least until manufacturers have introduced a couple more safety measures so they can justify relaxing the siting requirements entirely. Given that I can have a (unsealed) 13kg canister of propane in a boat, or for that matter a house, they feel a bit over the top anyway!
One way or another there seems to be sufficient wiggle room that heat pump installations need not be prevented.
- 2,690 Topics
- 63.1 K Posts
- 877 Online
- 7,099 Members
RE: How do I set up Tesla Powerwall export for saving sessions since AI Takeover?
@papahuhu Please remember I did state a range for summe...
By Toodles , 3 minutes ago
RE: GivEnergy inverter tripping due to over-voltage?
Yesterday i had a single overvoltage event. But that mu...
By Tim441 , 3 hours ago
RE: Design Of Cascade System Replacing Undersized ASHP
I don't know the full details of your house or installa...
By Temperature_Gradient , 4 hours ago
RE: Summer heat is becoming the new winter cold in the UK. What are you doing about it?
Some pics of my heat solutions… Bought the shut...
By Watcher , 4 hours ago
RE: Moving growatt axe batteries
@etchedpixels just been informed that you can’t have ba...
By David999 , 16 hours ago
RE: Anyone have experience with Daikin Multi+ for air to air & hot water?
Maybe, just maybe, if you are prepared to leave the doo...
By JamesPa , 16 hours ago
RE: How to heat a bathroom when using an air to air heat pump?
You can air/air a bathroom with a suitable ceiling or o...
By EtchedPixels , 16 hours ago
They've been extensively tested by folks like the Germa...
@majordennisbloodnok Similar, although no heat pump h...
By IanMK13 , 1 day ago
RE: vaillant arotherm plus - Failure - DHW
As expected it failed to run late yesterday with the sa...
By trebor12345 , 1 day ago
RE: Minimum and Zero Disrupt Heat Pump Installations
Personally, I don't always rate the "payback on install...
By HeatNoob , 2 days ago
RE: Adding additional Solar Panels to a DC coupled battery system
@transparent thanks. Will be sure to keep a record of s...
By bontwoody , 2 days ago
@jamespa Well, something along the lines of "three buse...
By ian33a , 2 days ago
