How To Deal With a Heat Pump Nightmare
We discuss the short fallings of MCS, consumer codes and certification bodies in protecting homeowners from subpar heat pump installations.
Please support us by sharing this podcast with friends, family, colleagues and on social media.
Sorry All, but after 25 months of complaints the NIC says of my "installation"
"You are NOT Going to like this ............But"
"Nothing can be done". ( NIC "officer" in a recent Telephone call, announcing "yet more "Sanctions against my "installer" )
My "installer" has been "STUCK OFF " from NIC/MCS registration THREE Times!.
The MCS in their wisdom re-installed my "installer" TWICE during the last two Years, presumably because of the loss of "the annual Registration fees paid by my , now former "installer".
The RECC, formerly independent , has now been "absorbed into " the MCS , joining the NIC-EIC in forming a triumvirate of "Charities".!!
Why "Charities " you may ask ?. Back comes the reply "that the MCS is a "Charity" because of it's Educational activities!" ( An MCS officer in another Telephone call!".
What "Educational Activities" ..........why Educating the general public about "Global Warming and Energy conservation!
The MCS "is a quality assurance scheme, currently owned by the Department of Energy and Climate Change (DECC) but soon to become a stand alone company.
My first question would be how do these companies obtain accreditation in the first place.
Some of the complainers on RHH unfortunately do not heed the advice provided, but would rather just complain.
Posted by: @derek-mMy first question would be how do these companies obtain accreditation in the first place.
This has been something I’ve been looking into, and frankly it makes my head hurt, which I’ve tried to cover here: https://renewableheatinghub.co.uk/why-your-mcs-certified-installer-might-not-be-as-competent-as-you-think
My "installation" has the same symptoms as that described in the "Skill-builder Channel " on You tube.
The Heat Pump User on Skill-builder has replaced , or removed, virtually the entire system.
The Heat -Geek Re-installer has:
1) Replaced the LG Heat Pump with a 12 Kw Valliant.
2) Removed a secondary Pump .
3) Removed a 50 Litre Buffer Tank.
4) Upgraded some water pipes to 28 mm.
Given that I have spent some £14000 on my Heat Pump, I can spend no more!
I am still forced to Pay £42 per month for an "installation" that has a Winter COP of 2.8 when the price of Electrical Energy is FOUR Times that of GAS Energy.!
Given that I have NO-Confidence in either my, now former "installer" , the NIC or the MCS I am Fed Up with Heat Pumps.!!
The NIC have said that "Regrettably .... You are not going to like this............
but, given that we have applied multiple Sanctions to your 'Installer' ......Nothing Can be DONE.!!"
Given the number of on-line complaints about the efficiency , Stability and installation fiascos of Heat Pumps .......... I am certainly Not Alone!
I am , in Winter, cold, rboke and scunnered with "Heat Pumps & this "Industry" !!
The Skill Builder Site is now showing the results of a Complete replacement of a Faulty Heat Pump Installation.
The SCOP has been increased to circa 3.99 , a dramatic improvement!
With evidence of such improvement , confidence in the re-installer, HEAT GEEK will soar!
Unfortunately, I will be unable to use HEAT GEEK given the ever greater costs of a complete re-build.
Even , if I could afford the re-installation I would still be forced to pay for the old "installation".
All this shows that Heat Pumps CAN be repaired with experienced and knowledgeable people, if you can afford them!
The RE-installation involved the complete replacement of the Heat Pump itself , with a large number of improvements , upgrades and replacements!
Again, HEAT GEEK are inundated with customers who have badly installed , badly designed , unstable, inefficient and costly Heat Pumps.
It CAN be Done, you can get a workable Heat Pump!
Following a recent visit by a NIC Engineer could I make the following observations concerning metering.
RHI and Metering
My Heat Pump was originally "designed", and costed , with a £500 Water Meter to provide evidence of the performance of my Heat Pump for RHI.
With the demise of RHI the requirement for a Water Meter was withdrawn.
NIC and Metering
I fitted a Water meter at the start of the Radiator circuit in July 2023.
The NIC "engineer" maintained that the withdrawal of RHI implied that No Water Meter "should be fitted to my Heat Pump".
The NIC "Engineer" , with two "Engineers" from my then "installer", said that my Heat Pump would be repaired and replaced if.......
I agreed to the removal of ALL Metering!
My Metering
I refused to accept Any upgrade or Replacement Heat Pump , Tank and Buffer that involved the removal of my extensive Heat Pump metering!
Quotes about metering
I was reminded of Einstein's famous quip that "the notion that the Moon only exists if I am Looking at it , is absurd!".
or of another , probably Scots, quote that " if ye cannae measure it , ye don't understand it!"
or A Quote from a Visiting French Samsung engineer that " Only the German's Really understand Heat Pumps"
Wall Conductivity Scam
The Following Power consumption estimate was Initially produced by my "Installer" to justify the "installation of a 6.5 Kw Heat Pump!
Note the Estimated power required , and , note the Room Wall Conductivity used.
The Following Power consumption estimate was produced four months after the "installation " to justify the "installation " of a 5 Kw Heat Pump.
Warning !.........Some "installers" are " modifying Wall Thermal conductances , U to justify the "installation " of the Wrong Power of Heat Pump!!
My "Installer" was STRUCK-OFF for the Third time because of this "mistake".
COP, SCOP and the REAL Coefficient of Performance ?
My Heat Pump was originally to be fitted with a Water Heat Meter at a cost of £500 for the RHI program.
The RHI being stopped in 2022 , resulted in the withdrawal of my Water Meter.
The RHI Water meter was to have been positioned at the start of the Radiator Circuit measuring the Actual Power , Water Temperature Out and Return.
I later fitted my own "Sharky" Water Power Meter to measure the ACTUAL POWER and WATER TEMPERATURES at the beginning of the Radiator circuit.
Th following shows the ACTUAL COP from my Water Meter in comparison to the COP as measured by My SAMSUNG Heat Pump.
Notice the difference !!
My Average ACTUAL COP is 2.17 for 2024 compared to a Samsung Displayed COP of 2.86!!
Conclusion:
To get the ACTUAL REAL COP use a Power Water Meter!!
What is my REAL Water Temperature ?
My Heat Pump system was "designed" at a Specified Water Temperature of 50 C.
If I set the Front panel controls on my Samsung Heat Pump to 50 C the Radiators should be heated with water at 50 C ?
My Front panel Temperature has NEVER achieved a Water Temperature of 50 C , with a maximum * of 47.5 C !
My Water Power Meter displays a Maximum Temperature of 42 C ,( 43 -41 )/2 C.
My Living Room Radiator shows the Maximum Input Temperature to be 32 C , ( 34-31)/2 C.
At 32 C my Stelrad Living room Radiator has a multiplication factor of X 0.63 at 32 C.
The Stelrad has a power rating of 2156 Watts @ 50 C, when, operating at a factor of 0.63 , the power will be 1466 Watts.
"Designed" with no allowance made for a Heat Exchanger between the Heat Pump and the Radiator circuits , these Specifications and measurements are all but meaningless!
* Absolute maximum set with the Water Law Thermostat graph set to a Water Temperature of 50 C with an outdoor Temperature of -5 C and A Water Law Thermostat Offset of +5 C
"The King is in the Altogether "
@iantelescope The usual arrangement is that DHW heating is carried out by the heat pump as a separated task whilst space heating is not in use; this is achieved by boosting the flow temperature of the water passing through the hot water tank mechanism - I think the usual setting is a few degrees above the desired DHW temperature. An occasional anti-legionella cycle is run with the aid of a supplementary heater (usually an immersion heater in the tank) to raise the water temperature to approx. 60 degrees. Though during the DHW heating cycles, the space heating is not running (a diverter valve is usually employed to do this) 9nce complete, the space heating may continue which would be at the temperature programmed for the purpose. (Usually, this will be somewhat lower than 50 degrees to ensure a better COP. Regards, Toodles.
Hi Toodles,
Nice to hear from a fellow Seventy-Six year old, OAP .
Water-Heating.
I used my Heat Pump Water-Heater throughout the winter of 22-23 Only to be delivered of an Electricity bill more than 2 and a half times my Gas Bill for 2021.
This winter, 23-24, I have stopped the Water-Heater but not the "Legionella Routine" with my Electricity consumption reducing by 10% .
With repayments of £42 per month , the Running costs of my Heat Pump became completely unaffordable!
Water-Heater or Space-Heater Priority?
My Heat -pump also Switches between Water-Heating and Space heating based on a priority.
The Water Heater system works but................at a cost in kWh and £'s
I have thought of replacing the massive 200 Litre tank with a on-call Electric "under Sink" water heater, but , on seeing the costs thought better of it !
NIC
Installed by a company in Govan , Glasgow my heat pump has been a two year nightmare, with my "installer" being Struck-off Three times by the MCS/NIC for an assortment of failings, With the NIC finally admitting defeat , saying that " You (me!) are Not going to like this ........................
..............But Nothing can now be Done , Good luck !"
I have finally come to the conclusion that Nobody is going to repair or replace my Heat pump .............
..........................and that the best that I do is simply admit that my system repair is "uneconomic".
I cannot afford to have this Heat Pump repaired or replaced, and , look with envy at the replacement Heat-pumps fitted by Heat-Geeks, see the Skill-builder You tube videos.
Your photograph looks a wee bit like me ...........
- 22 Forums
- 2,089 Topics
- 45.9 K Posts
- 26 Online
- 3,375 Members
@benson, I know I sent you an IM but on reflection it m...
By Majordennisbloodnok , 20 minutes ago
Depends on the flow temperature; the Czech data sheet i...
By JamesPa , 3 hours ago
Thanks @lucia I look forward to some technical facts as...
By Judith , 3 hours ago
Fantastic news IMHO and congratulations to @mars for ma...
By JamesPa , 7 hours ago
There is a real disconnect between how performance is ...
By Aaron , 17 hours ago
Some thoughts from me, having been through the ECO4 pro...
By Old_Scientist , 24 hours ago
By Old_Scientist , 1 day ago
@ashp-bobba ‘Wattson, how many grammes of Co2 are you r...
RE: Plate heat exchanger considerations
As far as I can tell my vented system would have a peak...
By Scalextrix , 2 days ago
RE: Air Changes per Hour - ACH and the MCS requirement
There have been a few discussions dotted around (e.g. I...
By Declan90 , 2 days ago
Having made some enquiries locally I have found a compa...
By Morgan , 2 days ago
RE: I don't need any heating in the summer. How do I turn my Samsung heat pump off?
Thats great Someone else is struggling with this in a...
@bart Best of luck moving forward, I look forward to he...
By ASHP-BOBBA , 3 days ago
RE: Ecodan EMP2 kit - is it any good?
Please note: heat meter accuracy at 95+% is as long as ...
By ASHP-BOBBA , 4 days ago
