DIY blower door testing
Blower door testing (google it!) is a great way to find out how leaky your house is, and now is a good time to do it - before it gets cold.
A few years ago I made a cheap diy version of this, which fits over a window. It's pretty simple to do, well in the diy category I think. It's a car radiator fan - I picked one from a crashed sports car on ebay, and a fixed 15V 16A supply. It works best to fit the fan blowing out of the house, so that any leakages pull air inwards, which is easiest to detect with the back of your hand. I used it to help make our house airtight, ready for mvhr some time back. Pulled it out again to check how things were!
If all of this goes well, you can also measure the leakyness - this involves measuring the pressure and the air flowrate. TBH this is less useful than finding and fixing the faults in the first place. You can make a manometer, and buy a cheap airspeed meter.
Attached is a pic of the fan in place!
I found a few places that I will fix:
Around the lofthatch handle
A few sockets still leak
The back of our bath leaks
Toilet overflow!
- 2,378 Topics
- 53.9 K Posts
- 134 Online
- 6,060 Members
RE: Grant ASHP 17.5 kw. weather curve
Firstly welcome to the forums. I hope you ar...
By JamesPa , 3 hours ago
@toodles We had a reroof concurrently with the PV in...
By Papahuhu , 3 hours ago
RE: Cascade 2x Grant Areona 10kw ASHP - Ongoing setup issues
(Almost) all heat pumps do defrost by taking heat from ...
By JamesPa , 4 hours ago
The Great British Heat Pump Owner Persona Survey: Let's Build Our Archetype!
Happy New Year everyone! As we head into 2026, ...
By Mars , 4 hours ago
Seems to be the only logical explanation. Our ASHP was ...
By benson , 6 hours ago
@jamespa thanks, yes it seemed mad to me. An exert f...
By Papahuhu , 6 hours ago
RE: Optimum new build house design for Heat Pump
From first principles I would say: Definitel...
By JamesPa , 7 hours ago
As good a place as any to drop this video:/p>
By Mars , 11 hours ago
@transparent D'Oh - I did look before I posted but I mi...
By dr_dongle , 12 hours ago
Compatibility with Samsung AE080RXYDEH
I am new to all this. We have a SamsungAE080RXYDEH that...
By John999 , 12 hours ago
@batpred Maybe you should buy your additional batter...
By Bash , 14 hours ago
RE: Data Accuracy Problem: Daikin 8kW Heat Pump's Onecta App vs MMI Power Consumption
@nursethescreens Yes, comfort and happiness of the fami...
By Toodles , 14 hours ago
Thanks folks. I had tried googling an ethernet lab adap...
By z8lccda , 1 day ago
RE: Changing from 4-port buffer to volumizer
@toodles I'm not concerned that the behaviour is not no...
By Andy1618 , 1 day ago
I agree, and I think there are two things in play here....
By cathodeRay , 1 day ago
RE: Water Hammer After Heat Pump Install
That's really helpful. Yor last sentence confirms it'...
RE: Help needed with Grant Aerona 3 issues
First time posting so bear with me. Some bits that have...
By Adamp , 2 days ago
RE: Mitsu PUHZ-SW120YHA + EHSC-VM20Uk - Performance
All understood. Obviously its a bit house de...
