New build ASHP and Solar Installation Certificates
I am in the process of buying a new build property which has solar panels, air source heat pump, heat recovery system and underfloor heating. I wanted to know what certificates I should be looking for the work carried out.
I know there should be:
- A Domestic Electric Installation Certificate for the whole electrical installation.
- A MCS certificate for installation and equipment used on the solar panels
What else should I be looking for?
Vaillant aroTHERM plus 3.5kW
50 litre volumiser
3.6KW solar panels
Tesla 13.5kw Powerwall 3
- 2,767 Topics
- 65.1 K Posts
- 704 Online
- 7,169 Members
Recommendations in Ely (Cambs) area for Full setup checks on Nibe HP setup for House.
Hi All, a friend had a Nibe F2040-12 12Kw heatpump in...
By StuChi , 1 hour ago
My heat pump receives sunlight, so when the fan is not ...
By bobflux , 2 hours ago
You should (almost) always reject having a buffer, by w...
By JamesPa , 18 hours ago
By Toodles , 22 hours ago
@majordennisbloodnok I do sympathise. On the original...
By springswood , 24 hours ago
No, but the heat pump must be capable of delivering a S...
Sorry to hear about the problems, its going to be somet...
By bobflux , 2 days ago
RE: Vaillant Arotherm Plus 7KW need a service on it
booked it with Vaillant. will use them until i can find...
By AdamK , 2 days ago
I have seen it stated that the declared calorific value...
RE: Two heating zones to one zone
@transparent Many thanks. The garage is fairly well ...
By Profzarkov , 3 days ago
RE: Vaillant Aurotherm - Heater Wire Position
Ah, good point. I need to check if this was installed i...
By Batpred , 3 days ago
@batpred thanks for getting a copy. Appreciate the supp...
