When registering, please note that you will not be able to change your username. It is also very important that you read and understand the Forum Rules & Terms of Use before signing up.
Renewable Heating Hub Forums
Well & Truly Off The Grid
Buy & Sell
- 25 Forums
- 1,429 Topics
- 30 K Posts
- 30 Online
- 1,215 Members
Making best use of Agile with a battery and ASHP
I'm new to the forum, and finding the existing posts ve...
By jamesw , 1 hour ago
RE: Is this a bad installation and is there something wrong with my Samsung heat pump?
@kenbone no need for what kenbone regarding the 100watt...
By David999 , 23 hours ago
RE: Insulation of flow and return Heat Pump piping
@mike-h Thanks Mike. Toodles.
By Toodles , 1 day ago
RE: Bivalent (or even trivalent!) system design options for a new GSHP installation
For your interest @algienon this is what happens when a...
By Transparent , 1 day ago
RE: Rising Damp – Production Recommendation
Yet another topic I'm not an expert in. Nonetheless, th...
RE: Noise problems with newly installed Samsung 8kW ASHP
@editor yes, the more I read the forum posts the more I...
By sjn , 1 day ago
RE: Observations on my Ecodan's estimates of energy consumed and delivered
As it is possible for the FTC to be powered from a sepa...
By HarriUp , 2 days ago
RE: ASHP Cut-off Temperatures: What's Your Setting and is a Your Heating Still On?
My system has been running 24/7 on weather compensation...
By HughF , 2 days ago
RE: Heat Pump Truth or Myth#2 - Cycling uses a lot of power and ruins your COP
I cannot state that I have noticed that our A2A heat pu...
By Derek M , 2 days ago
RE: Maximising Savings: Navigating My First Year with Octopus Energy and Heat Pump Running Costs
@toodles I can also happily report that the Agile tarif...
By Steve D , 2 days ago
@editor As we all know, RHH always strive to educate, e...
@bontwoody I used the website link to contact them for ...
RE: Samsung ASHP power cycling
I have considered that and I would have expected to see...
By Blaine_t , 2 days ago
RE: 14kW Midea ASHP in an old leaky building
Hi @batalto. I see you have a Midea ASHP and I am sched...
By Kbedders , 2 days ago
RE: Additional ASHP kW for DHW cylinder?
We're in a similar boat to you with a hodgepodge of dif...
Anyway, so far we have all missed the main protagonist ...
@ivanopinion Im in the same team as Ivan. I think for a...
By bontwoody , 3 days ago
RE: Issues with Vaillant connectivity via the MyCONNECT gateway
@drew-pa I don't know about hard work! It is pretty cl...
By dr_dongle , 4 days ago
RE: Are Solar Diverters Necessary for Homes with ASHPs and Solar PV?
@editor No, I made one 😀 Loft insulation all...
By Andris , 5 days ago
@hughf Thanks for that. Ah so they are talking about ...
By IRMartini , 5 days ago
Latest Topics
By jamesw 1 hour ago
By Toodles 2 days ago
By Blaine_t 2 days ago
By Mars 2 days ago
By Project_Electrify 3 days ago
By IRMartini 5 days ago
Riello / Midea - modbus set flow temp
By stuartornum 6 days ago
Ecodan software update. Real or scam?
By Morgan 6 days ago
