Defrost cycle question
Sorry if this is a daft question:
But after reading about defrost cycles I'm pretty sure I understand the basics of what is happening.
Instead of heat from the environment being used the increase the temp of the heating circuit, during the defrost cycle heat from the heating circuit is used to warm the environment (melt the ice off the radiator)
All the descriptions I've read use the word reverse, the heat pump works in reverse or the heat pump reverses.
Does the actual water pump pumping the water round the heating circuit reverse direction?
Or is the 'reverse' just referring to the heating 'mode' reversing (going from heating to cooling) rather than the water flow reversing.
I'm pretty sure its just talking about the mode but after lots of searching I could find nothing definitive on the water pump direction.
A valve in the heat pump causes the direction of the refrigerant to change. The water circuit carries on pumping as usual.
@hughf Thanks for that.
Ah so they are talking about the refrigerant circuit direction reversing.
I knew it couldn't be the water circuit logically, I think it has been a rather long week 😆
- 2,771 Topics
- 65.3 K Posts
- 1,149 Online
- 7,174 Members
Agreed. There´s another aspect that could eventually...
By Batpred , 4 hours ago
By Mars , 6 hours ago
By Jimcub , 8 hours ago
By JamesPa , 9 hours ago
@jamespa My RFQ went out to 20 companies via email; in ...
By Toodles , 10 hours ago
By Prunus , 11 hours ago
Hmmm. We have 500sq metres here (including some very hi...
By Carpenterstation , 12 hours ago
Thank you @majordennisbloodnok – that means a lot, part...
Have you looked at the Nibe website? They list their ap...
By Lizzie , 2 days ago
By Papahuhu , 3 days ago
By Batpred , 3 days ago
By Rob of York , 4 days ago
By springswood , 4 days ago
