When registering, please note that you will not be able to change your username. It is also very important that you read and understand the Forum Rules & Terms of Use before signing up.
Renewable Heating Hub Forums
Well & Truly Off The Grid
Buy & Sell
- 24 Forums
- 1,413 Topics
- 29.7 K Posts
- 30 Online
- 1,197 Members
RE: ASHP Advice: High Temperature vs. Low Temperature Heat Pump For Microbore
Hi Mars, I am running a Samsung 12Kw High Temperature...
By TechnoGeek , 15 mins ago
@gary Thanks. If you don't mind me asking, what is the...
By MattC , 21 mins ago
RE: Installing your own ASHP - DIY
The work continues! I've finally finished doing my s...
By tomasmcguinness , 1 hour ago
RE: Microbore Central Heating Plumbing, will it be a barrier / pain?
@mattc All the existing (designed for T50) radiators ar...
By IanMK13 , 13 hours ago
RE: Gas Combi to ASHP - Making sense of survey results and proposal.
Hi Ian, as a Samsung ASHP owner, I have some concerns a...
By Mike H , 14 hours ago
The temporary fix has reconnected about 60% of users, a...
By Abernyte , 15 hours ago
RE: Vaillant Arotherm Settings for New Installation
You are correct. I just tend to over simplify things. ...
By Drew Pa , 17 hours ago
RE: What is Wrong with our Heat Pump Installation?
Having to run the heat pump during the summer for DHW s...
By Toodles , 17 hours ago
Issues with Vaillant connectivity via the MyCONNECT gateway
I'm sensing a variety of issues with Vaillant connectiv...
By dr_dongle , 18 hours ago
Interesting heat pumps installations
Thought it would be cool to share photos of interesting...
By Mars , 19 hours ago
@Toodles That's very interesting to hear, thanks. I ha...
By dr_dongle , 19 hours ago
RE: Massive Electricity Cost for Running My Air Source Heat Pump
@allyfish In fairness installer has replied stra...
By Holts , 1 day ago
Fossil Fuel Fired Heating v Heat Pump?
Now, when one burnt coal, you knew you had real heating...
Based on my experience, the answer is no, unless the ho...
By IvanOpinion , 2 days ago
RE: Are Solar Diverters Necessary for Homes with ASHPs and Solar PV?
@zzxap19 that's a fair point. With the eddi, is it poss...
RE: Delivering a smart and secure electricity system: government consultation
"I don't think I'll need to refer to past iterations of...
By eggnchips , 2 days ago
RE: Error on Immersun – Error 8 Load Short Circuit
@julesmp8 fingers crossed. I have to say our Immersu...
Viessmann Vitocal 250-A in the UK
Hi all, I was looking the some of the most efficient ...
By treehugger , 3 days ago
Latest Topics
By dr_dongle 18 hours ago
By Mars 19 hours ago
By Mars 2 days ago
By Toodles 2 days ago
By treehugger 3 days ago
By HUBB84 6 days ago
By jswhite 6 days ago
