Simple CT-clamp monitor which is battery-powered or plugs in to 13A socket for ASHP monitoring
Hi all. I have a potentially silly question :). I've had a Daikin ASHP since 2009 but I've never known how much energy it uses. I would therefore like to get a CT-clamp based monitor to attach to its power cable (assuming I can find the right cable!). I'd like to start simple so ideally I want one that:
- Records daily / weekly usage - as long as I can look at a screen, look at the numbers and update a spreadsheet that's fine
- Doesn't need to be wired into the consumer unit, just a simple battery powered unit, or one with a simple 13A plug
In other words, while the multi-device consumer unit monitors from Shelly or Sue look great, I can't install them because I'm not an electrician.
I am struggling to find anything that fits the bill - do such devices exist?
Many thanks in advance for your help!
Built house with 16kw gen-1 Daikin heat pump in 2008. Installed replacement 3rd-gen 9kw Daikin heat pump 2025. 5.6kw solar. Heat recovery and ventilation. UFH. Massive insulation.
- 2,774 Topics
- 65.4 K Posts
- 47 Online
- 7,177 Members
@mrkfm, I’m definitely not trying to put anyone off get...
By Mars , 4 minutes ago
I agree, which is why I am currently resisting buying a...
By JamesPa , 25 minutes ago
Is there any expected time frame for an update to be ab...
By Singlespeed , 4 hours ago
Posted by: @springswood I confess to becoming a litt...
By Rob of York , 5 hours ago
Analysis of the economics of switching to an A2W ASHP compared to other heat sources
This post aims to analyse the economics of installing, ...
By Rob of York , 9 hours ago
@editor does that mean you have to have two separate ex...
By mrkfm , 1 day ago
Posted by: @ian-s Could always use the money saved o...
By Rob of York , 1 day ago
Depends on what controls the pump! Thats the whole poi...
@renewables345 I would say if it a new build it’s no mo...
By Aventus Eco , 3 days ago
