@dansus
To achieve a full 3kW (3000W / 13A) continuous AC feed-in into your home grid, you will need equip 1× PowerFlex 3000 and at least 1× Extra Battery module (e.g., PFA4000) (or 2× Extra Batteries for optimal storage capacity and battery lifespan).
Operating at a continuous 3000W output requires the discharge C-rate supported by adding at least one expansion battery pack. A single standalone base unit operates at a lower continuous output limit.
Once your electrician has completed the fixed AC installation (via a dedicated CU circuit / switched isolator):
1. Open the Indevolt App during initial system commissioning.
2. Select "Fixed Grid-Tied / Hardwired Mode".
3. Accept the in-app Compliance Disclaimer confirming that the system is hardwired according to BS 7671 and registered under G98.
4. The firmware will immediately unlock the full 3000W AC grid feed-in limit.
Hope this gives you the exact hardware list you need for your pre-order! Feel free to ask if you need any further specs for your electrician!
⚡ Indevolt UK Technical Team
Official Support | Smart Energy Storage & Home Automation Solutions
🛠️ Discord: https://discord.gg/aZTvvTK9pt
📧 Support: support.uk@indevolt.com
Posted by: @indevolt-techHope this gives you the exact hardware list you need for your pre-order! Feel free to ask if you need any further specs for your electrician!
This is very helpful, thank you.
I seem to recall that you may have suggested that, provided an appropriately registered electrician installs and certifies the circuit up to a suitable breaker, the final connection to the inverter can be made by a reasonably competent householder. From my reading of Part P it is possible to infer that, the installation of the new circuit either requires a competent person or is notifiable under building regs, connecting up the inverter if done separately (unless its in a 'special location') is not at least to my reading. Can you clarify your interpretation/correct my memory please? G9x is separate of course, Im not asking about that just about the electrical installation itself.
Posted by: @jamespaI seem to recall that you may have suggested that, provided an appropriately registered electrician installs and certifies the circuit up to a suitable breaker, the final connection to the inverter can be made by a reasonably competent householder.
That depends on the inverter. Some require hard-wired 240v AC connections, whereas others have a plug & socket for the mains input.
Indevolt are using a circular 3-pin connector for grid input/output. If the electrician has installed a switched fused-spur and connected the Indevolt flying lead to it, then that's all that would be covered by his Part-P certificate.
Customers should be paying greater attention to the PV panel inputs rather than thinking that it's only the mains which can bite! There are no regulations to prohibit end-users from connecting MC4 plugs and sockets. But a typical solar panel might be outputting 40-50v DC (open circuit), depending on the model. Although the Indevolt Powerflex specification states 11v-60v for each MPPT connection, I can foresee people trying to put two in series.
Unlike AC electricity, the human body doesn't have a reflex action to a DC shock. It's rather like the DC connector 'sticks' to the skin.
This is another of those areas where the public have insufficient knowledge of energy matters to understand what is and isn't safe.
Posted by: @transparentIndevolt are using a circular 3-pin connector for grid input/output. If the electrician has installed a switched fused-spur and connected the Indevolt flying lead to it, then that's all that would be covered by his Part-P certificate.
Thanks, however that's an answer to a subtly different question. What, in your view, is the situation if the electrician does wiring up to a breaker (other than in a "special place") certifies, and leaves? To my reading Part P requires any connection of equipment (eg an inverter) to the breaker to be safe, but it does not require it to be done by a 'competent person' (in the technical sense) or notified.
Just wondering what we currently think may be good options for battery plugin in the uk. Just a simple system with a ct clamp and looking for a low £/kwh.
I saw some around £370/kwh. Some of these systems are modular, like in 2kwh boxes.
@batpred Plug in batteries are not yet legal so maybe best to hang on until they are if you want to be certain of compliance
Posted by: @batpredwondering what we currently think may be good options for battery plugin in the uk. Just a simple system with a ct clamp and looking for a low £/kwh.
... and you're aware that Plug-in Storage is not yet permitted in the UK ?
You can buy such a unit, but it would need to be hardwired by a qualified electrician.
It's not OK to fit a 13A square-pin plug and connect it via a wall socket.
See this other discussion topic on battery storage without solar. There I provide an illustration of how the requirement for hard-wiring can be satisfied using a fused-switched-spur outlet.
The problem with giving an answer to your question is that there isn't yet an agreed definition of what might be classed as a plug-in battery when the Government does make it legal.
It may or may not be limited to an output not exceeding 800w, which is the limit presently applied to plug-in solar.
But there could be further constraints in order to provide a better safety margin for current being injected into an existing ring-main.
Government will need to consider dwellings which have already purchased the two plug-in solar kits which are permitted by law. How should a plug-in storage device 'decide' whether it is sharing the same ring-main as those two existing plug-in solar inverters?
Will there be a need for software to prevent three plug-in kits exporting at 800w simultaneously?
There's a lot to consider, quite apart from cost per kWh
Posted by: @transparent... and you're aware that Plug-in Storage is not yet permitted in the UK ?
It's not OK to fit a 13A square-pin plug and connect it via a wall socket.See this other discussion topic on battery storage without solar. There I provide an illustration of how the requirement for hard-wiring can be satisfied using a fused-switched-spur outlet.
To be honest, I was not sure about the status. I see that the approved solar DIY is without energy storage..
I will take a look at the link, thanks for sharing.
It would be useful to understand what kit currently being sold for electrician install is likely to be best for DIY (once that is approved).
I've got a podcast recording scheduled this week where we're going to tackle where plug-in batteries are and what's likely to happen to them in the UK from a regulation perspective.
As we know here, the success or not of plug-in storage is extremely dependent on the ease of installation.
That is of paramount importance for the majority of the population, who will have little idea which of their 13A sockets are on which ring circuit.
In the meantime, the cost of hardware required for storage continues to fall.
If plug-in storage becomes too difficult to understand or implement, such that prospective customers have to employ an electrician anyway, then you might as well opt for a larger battery+inverter to be hardwired.
The most common LiFePO4 cell, with guaranteed 280Ah capacity, can now be purchased for £43.50 + carriage & VAT.
That was £76 just nine months ago.
These are prices for stock already held in Poland.
Since the military action in the Strait of Hormuz and the Bab-el-Mandeb Strait, the Chinese sellers have learnt fast. They've established warehouse bases which are isolated from delays and uncertainty over maritime shipping. Their products can now be supplied faster and cheaper, using European courier companies we are already familiar with, like DHL.
This puts pressure on DESNZ to ensure that plug-in storage really does have ease-of-use, and can work seamlessly alongside a couple of plug-in solar kits.
If it comes with "strings attached" resulting in many homes still needing professional installation, or if the capacity and rates of output (800w?) become too constrained, then there are going to be a number of competitors who will step into the void left by the demise of GivEnergy.
It doesn't cost much more for an electrician to install a 5kW all-in-one inverter/battery unit than it does to hardwire a plug-in storage kit because the red-tape became too onerous for suppliers or consumers.
Currently viewing this topic 5 guests.
- 2,830 Topics
- 67.3 K Posts
- 1,623 Online
- 7,253 Members
