Hydrogen Ready
Posted by: @etchedpixels@jamespa Energy storage is not a sensible use for hydrogen. It leaks, it attacks the containment and it's extremely hard to store safety. Even well run hydrogen storing/using plants have explosions
I hadn't realised that but it sounds like another nail in the already firmly sealed coffin of hydrogen domestic heating.
Posted by: @etchedpixelsThere are lots of things you can do when the sun shines
or, presumably, when the wind blows!
There's some very useful technical points being made here by our learned members 😊
Whilst our minds are considering hydrogen may I also draw our attention to its possible use in CCGT generation plants. There's one rated at 850MW at Langage, just outside Plymouth which has been producing green hydrogen to store and then mix with Natural Gas.
I have no first-hand knowledge of how the project has been going. However the West Country often has surplus generation from renewable sources, and it would seem to be a sensible use of that electricity for hydrolysis. The alternative is to constrain output because the grid must not be permitted to transfer more of that power eastwards towards London.
What concerns me are the worldwide reports that a methane/hydrogen mix has detrimental effects on gas turbines and is more difficult to control.
The principle arguments are these:
- the combustion temperature is at least 200°C higher because hydrogen has higher adiabatic flame temperature than natural gas. This causes thermal stress on components in the jet stream and the need for greater cooling (sometimes using the hydrogen pipes before they get routed to the inlet nozzles)
- the flame rate of hydrogen is 5-7 times greater than methane/propane. The means the point of combustion moves back towards the inlet nozzles and causes turbulance. Without skilled engineering there is a risk of flashback.
- the rapid hydrogen-mix flame increases the formation of Nitrogen Oxides (NOx). Either the exhaust requires recycling or else the nozzle design must be changed. Without remediation, the flue would be expelling polluting gases beyond the statutory limits.
- the higher proportion of water-vapour in the exhaust increases thermal losses up the flue
The combustion issues are not nearly so problematic for a hydrogen-only gas turbine. But you'd require massive storage facilities and large pipes because the calorific value of natural gas is at least 37MJ/m³ whereas hydrogen is only 12MJ/m³
There's a technical paper on MDPI which explains the physics in much greater depth. It's partly a resumé of international research into the subject matter, and well illustrated.
I hope DESNZ is sufficiently aware of these issues. We really don't want an ill-considered announcement by the Government, proclaiming that we're going to invest heavily in hydrogen-mix gas turbine plants to achieve net zero.
A couple of the mixed hydrogen/natural gas power stations on the National Infrastructure list, obviously not guaranteed to progress. Only the first one explicitly mentions a blend of hydrogen/natural gas.
"Ferrybridge Next Generation Power Station will be designed to run on 100% hydrogen, natural gas or a blend of natural gas and hydrogen."
https://national-infrastructure-consenting.planninginspectorate.gov.uk/projects/EN0110011
https://national-infrastructure-consenting.planninginspectorate.gov.uk/projects/EN0110007
The second one I suspect will progress much faster, and for anyone in the area and interested there are consultation events this week today and Wednesday you can attend in person. Info on their websites.
https://eethydrogenpower.com/engage/chp2planning/
EET also have another smaller hydrogen power station CHP1 on the same site which is progressing outside the national infrastructure process due to it's smaller size.
The Triton power station in the Humber has been working with Mitsubishi on upgrading to handle a natural gas/hydrogen blend.
https://power.mhi.com/regions/amer/products/hydrogen-gas-turbine
https://www.tritonpower.co.uk/
Be interesting to see how things evolve in the UK and elsewhere with Mitsubishi and their other projects.
Posted by: @transparentThere's some very useful technical points being made here by our learned members 😊
The alternative would be to move some productive energy users to where there is power and give them better pricing, but neither side of our oxbridge ppe political class appear to believe in market forces when it might move things out of the London bubble. Thus we become ever more "Moscow on Thames"
The full cycle efficiency of hydrogen as energy storage is terrible so you'd be far better moving things to use the power in the first place.
Posted by: @etchedpixelsThe full cycle efficiency of hydrogen as energy storage is terrible so you'd be far better moving things to use the power in the first place.
There's a company called Xlinks who are proposing just that.
They want to build a Data Centre and BESS on the hills of North Devon, connected to Alverdiscott Grid Supply Point by a new 3km spur off the 400kV Transmission Grid...
... for which you'll need to see the Data Centre topic here 😊
Thanks @jeff !
Posted by: @jamespaI hadn't realised that but it sounds like another nail in the already firmly sealed coffin of hydrogen domestic heating.
Someone will say that they can mix up to 5% in the gas network..
I still agree that cannot be sold as mission achieved! Even by snake oil salespeople..
Posted by: @batpredI still agree that cannot be sold as mission achieved! Even by snake oil salespeople..
Biofuel?
Biofuels don't scale. Or as someone once beautifully put it "biofuels are crap"
We've got a bunch of very useful biofuels like methane digesters at small scale but once you try and do a lot of it you essentially run out of poop and then you end up either pretending that carving up ancient forests is "renewables" or taking huge amounts of farm land out of circulation to make stuff like ethanol rather than feed people. This unsurprisingly ups the price of food in that state and makes people very angry.
Posted by: @etchedpixelsBiofuels don't scale. Or as someone once beautifully put it "biofuels are crap"
I was thinking that the biofuel would be the snake oil sold by the dedicated salesmen
I thought the cr*p came first and the biofuel came afterwards.
Oh, and if they don't "scale" then snake-oil definitely can't be a biofuel....
OK, taxi's already ordered; I'll get my coat.
Another Hydrogen mix example.
Just commisioned in Germany and undergoing trials with a mix of hydrogen up to 100% to generate electricity. This time built by RWE
Largest in Europe.
Be interesting watch RWE and Mitsubishi
I think that CCGT plant in Lingen is more likely to succeed that the one at Langage in Devon.
RWE and Kawasaki are building theirs to be hydrogen-compatible from the outset. That allows them to select components which can withstand higher temperatures, prevent condensate raining in the exhaust and overcome the flame-flashback issue.
The Langage plant was originally designed with no thoughts of a later conversion to a hydrogen mix. It's the conversion to a different fuel-mix which is problematic.
- 2,827 Topics
- 67.1 K Posts
- 1,159 Online
- 7,246 Members
