Hot water tank lose...
Hot water tank lose heat rapidly on random days
7 Users
9 Reactions
(@bazcurtis)
@bobflux Thanks once again for the information. I had a quick look at the expansion tank, but it is quite tight in the top of the cupboard behind some pipes. I am not sure I be able to check the pressure, but I will mention it.
If you were to give a percentage, what percentage would you say it is likely to be the valve? They have looked at it a few times and think it is in the correct position. Would the flow be enough to force its way through?
Page 4 / 4
