How quickly would y...
How quickly would you want/expect heat recovery to take from setback?
10 Users
9 Reactions
(@andrewj)
Octopus Cosy
@mk1234 yes, I have all that and no setback.  Except for heating the hot water which I can’t help because it does one or the other.  I’ve made some adjustments since my first original post but it hasn’t really been cold enough since to see if I’ve gone too far!  Anyway, I do have a much clearer view on what is happening and why.
(@rob-of-york)
@andrewj
Sounds like your house's thermal conduction loss are very low given the form of construction and triple glazing - give or take the small possibility of some insulation shifting.
The balance of heat capacity vs heat loss could be a factor in the feeling of cool air when the heating switches off, however, my parents bungalow had a similar form of construction (insulated wood frame) and didn't have that issue. One possibility could be that a fairly large proportion of your heat loss is due to air changes. If that's a bit higher than is ideal, it could be that the internal fabric of the building stays at roughly the set point, but nevertheless cool air drifts in and you notice that. Do you have lots of trickle vents open on your triple glazing (particularly on the side of the house that gets the most wind), or anything else that could lead to a bit higher rate of air changes?
(@andrewj)
Octopus Cosy
@rob-of-york no trickle vents and the humidity is pretty good, <50%. I don’t think air changes are unusual but I’ve never had it scientifically measured.  Nothing to point towards that anyway, I’ve always assumed that the plasterboard wall construction doesn’t lend itself very well to absorbing heat.
Page 8 / 8
