Grant Aerona3 13kw - Buffer Tank - Heating Journey
@toodles Thank you 🙂
I think I'm quiet lucky as the Grant pump is on Medium but the Wilo pump is on near enough max on the Variable differential pressure (Δp-v) setting. I suppose I could lower the grant pump to low and adjust the wilo from there but I think as its happy why mess with it. I get about 26 to 29 l/min which seems a decent flow.I do have a few radiators so I think going any lower will affect the heat output.
As I think I said before the flow temp from heat pump to Wilo is about 1-1.5c and the return is also the same. With the flow and return can vary but I'm not near the 8dt the manual recommends. If did do that to all the radiators I'm pretty sure the flow would be vastly reduced and would cause the system to cut on and off.
As i think my system is fairly oversized I've been messing with the heat curve instead and currently its at
Weather comp on On
Maxflow temp (coldest day) 42C
Min flow temp (mild day) 25C
Coldest outdoor point -3C
Mildest outdoor point 20C
As it was set up on 50c design i think i've made it much more efficient and the chain sawing is no where near as bad as before.
Instead of trying to balance radiators I'm going to balance rooms instead and I've bought some tuya thermometers and I'll go around and adjust them so hotter rooms are a bit cooler and thus making the colder rooms hopefully warmer to give a nice open heat. Like yourself we are pretty open plan also. I don't have a homely but I'm connected via home assistant which is very useful to adjust things. But the pump is controlled via the Drayton Wiser which is pretty good to be fair.
Currently viewing this topic 2 users ( Majordennisbloodnok, HeyMikey ) and 8 guests.
Recently viewed by users: Singlespeed 11 minutes ago, JamesPa 27 minutes ago.
- 2,820 Topics
- 66.9 K Posts
- 2,385 Online
- 7,234 Members
None of my radiators are undersized. Even the radiator...
By AndrewJ , 9 minutes ago
By HeyMikey , 36 minutes ago
Posted by: @jamespa I have been trying for 2 years o...
By Rob of York , 36 minutes ago
@fosterl2 I'm sure it's over simplified as there'...
By Singlespeed , 1 hour ago
By the same measure we should be insisting that all gas...
By Batpred , 13 hours ago
Got two or three heat pump quotes that don’t agree? Post them here.
One of the biggest sources of confusion I see on Renewa...
By Mars , 13 hours ago
I do not disagree with the concept of wanting to live a...
RE: Grant Aerona - Weather Compensation and Schedules
@taffonthetaff Yes, I have now gotten to the bottom of ...
By bontwoody , 16 hours ago
Occasionally our Grant R290 activates all three circuit...
By TaffontheTaff , 16 hours ago
@davec 47kwh for 3 days is very low, compared to what I...
By johnd , 18 hours ago
By JamesPa , 22 hours ago
By Mars , 22 hours ago
Do heat pump defrost cycles impair heat pump efficiency (COP values)?
The short answer is no, as far as I can see from data f...
By cathodeRay , 22 hours ago
