How quickly would you want/expect heat recovery to take from setback?
Posted by: @cathoderayI still think other weather factors apart from the OAT may be the cause of what you have observed. Standard weather compensation only sets the Set Leaving Water Temperature, and that indirectly sets the energy use. But on one day you might have favourable weather conditions eg solar gain, with the indoor air temperature (IAT) responding well, while on another day with unfavourable weather conditions eg rain and wind chill, the same amount of energy used struggles to make much difference because your heat loss has increased.
By the way, have you posted your design conditions heat loss? I've had a quick skim through the thread and couldn't see it anywhere.
Actually, good point. Yesterday was sunny for a good chunk of the day and could well have had some impact - it's been rainy and cloudy here all day and very little sun. If I was take a basic assumption of two bodies plus TV in the evening then that will also keep the temperature up (given our insulation.) I think the bigger indicator here then becomes what happens overnight when we are in bed and the sun has disappeared - and yes, it's colder as well. That can be seen on the temperature graph and it clearly wasn't able to maintain or recover the heat lost back to the target temperature. That itself might well confirm what you say and indicate that the flow temperature is now too low.
I haven't posted design heat loss in this thread, but it is in a larger Cosy 9 thread I initiated. Octopus calculated this at 8.5kWh at -3.4c. A subsequent heat loss survey by them after I was struggling to keep temperatures down determined it to be 7.5kWh. However, they also came back at that time with a revised radiator schedule that put 1kWh MORE heat into the house at the design temp. I sort of lost some faith with them at that point. It's also worth mentioning in the year before having the Cosy installed I used 9000kWh of gas for heating and hot water.
Currently viewing this topic 2 users ( AndrewJ, cathodeRay ) and 12 guests.
Recently viewed by users: bobflux 11 minutes ago, Toodles 57 minutes ago, JamesPa 14 minutes ago.
- 2,819 Topics
- 66.8 K Posts
- 1,518 Online
- 7,232 Members
@davec 47kwh for 3 days is very low, compared to what I...
By johnd , 5 minutes ago
The pool heat exchanger looks like one of thes...
By Singlespeed , 10 minutes ago
Actually, good point. Yesterday was sunny for a good c...
By AndrewJ , 17 minutes ago
I opted to buy sets of 16 bare LiFePO₄ cells and place ...
By Transparent , 41 minutes ago
This topic is straying into useful observations about t...
By Transparent , 3 hours ago
This opening sentence stopped my reading right at the s...
By QdsdHxJX9PFLfi7 , 4 hours ago
By JamesPa , 4 hours ago
By Mars , 5 hours ago
Do heat pump defrost cycles impair heat pump efficiency (COP values)?
The short answer is no, as far as I can see from data f...
By cathodeRay , 5 hours ago
By Judith , 23 hours ago
By hml1827 , 2 days ago
