Type 11 vs Type 22 ...
Type 11 vs Type 22 radiators with a 5 kW Vaillant aroTHERM plus heat pump
6 Users
2 Reactions
(@l8again)
Your energy: 12 kWh
@mrt  True, but not in the way that you think. As I have said before, I went for a Heat Geek Zero Disrupt survey which comes with a minimum combined efficiency guarantee. The survey offers 3 options each with different efficiencies.
Prior to the survey, I discussed my concerns with the installer about the size of the T22 radiator in my open plan kitchen. He suggested a bigger (1.7M by 0.6M K3 ) radiator to replace the existing T22. I then suggested that the kitchen T22 could be moved to replace an existing T11 radiator in my dining room. These were then fed into the survey as customer givens with a price of £500. The survey was run and Heat Geek came back with 3 offers: do nothing with an efficiency offer of 370% through to changing 5 radiators with an efficiency of 400%. The price to do nothing was £1700 (this included the new and moved radiator). The 400% efficiency option with 5 replacement radiators was £1500 more. I should add that for the higher efficiency offer, a 5kW Valliant was replaced with a 7kW heat pump.
After looking at the survey results I opted for the 400% efficiency offer. To seal the bargain, the installer agreed to move the T22 radiator from my lounge into my main bedroom (it was the only room where the existing radiator output would have been less than the predicted heat loss at -3C.) and the lounge radiator was being replaced.
I should add that the installer sits outwith the final survey results. These came from Heat Geek HQ. He thought that the bigger heat pump with the 400% efficiency guarantee was down to the increased water volume. He said that the bigger heat pump had the advantage of faster defrosting and longer periods between defrosts.The downside being the higher minimum modulation setting.
No flow temperature at the design temperature of -3C was offered in the survey. The subsequent MCS Certificate has a design flow temperature of 45C. I have yet to see a flow temperature above 38C and my location has had outside temperatures as low as -6.
Finally, 2 other factors that have come to light subsequently. I have PV solar and 27kWh of battery storage. On one dark and very cold day last week, I ended up having to run the house on peak price electricity for about 90 minutes. If I had gone for a lower efficiency system then this would have been longer because of the higher flow temperatures. It follows that it is not just the cost of extra radiators that is a consideration: it has to be radiators and the higher running cost. The other factor is that any subsequent radiator changes attract VAT.
This post was modified 5 hours ago by L8Again
Your energy: 60 kWh
@l8again And there is the intangible ‘Peace of Mind’ in the higher efficiency job - and the value is difficult to put a price on! 😊 Toodles.
 MrT
(@mrt)
New Member Member
Your energy: 31 kWh
@l8again
It seems that your overall system is larger but not buy much if your borderline 5-7kw ASHP, I remember having similar discussion, as my heat loss was 5.92Kw with the extension built, but in Cornwall we generally don't have long cold spells and design conditions are -1.3c but -6 is frightening. I was offered rad upgrades but because of upcoming changes in the house I declined them as some rooms that are the dining living area will become bedrooms and bedrooms become living areas. I'm able to change the rads myself in the future when it comes time and might yet end changing all of them. But when is the big question, so looking at what can be done sooner as temp to permanent fix, by looking at the heat needs as a bedroom rather than a dining room etc.
Did your heat pump drain the 27kwh batteries or do you have higher background usage. I guess you have to accept a few losses occasionally. It's only been 2 months into 'winter' with the worst yet to come I'm guessing.
I am concerned that now I am having shorter run times in milder weather because of the compromise and would like to address them, if I can.
(@rob-of-york)
Your energy: 29 kWh
Posted by: @mrt
 I have looked at the flow rate adjustment i can find it, It is set to 900 mbar (max) do you just adjust this figure down till the flow rate is affected? ie 850/800/750  then by checking on the screen to see if the 860lph drops? What sort of figure should i be looking for and does this change with different flow temps or once set does it adjust automatically. This is something i would like more information on before i start tinkering with it.
I think the controller in the Vaillaint Aerotherm aims to keep a constant flow rate, but then the compressor modulates down to only provide the heat needed. On milder days, as your house approaches / reaches the set temperature, the dT between flow and return will become just 1 to 2 degrees. This is likely what you are seeing, particularly as you don't have a problem with the house being cold. So, an adjustment to the flow rate may not be necessary.
That said, the 50 litre water volume seems quite low for a 5kW heat pump. At a 860 l/min flow rate (0.238 l/s) the whole volume of water in the system would take just 3.5 minutes to completely circulate back to the heat pump, which isn't very long for the heat transfer to take place.
The flow rate of 0.238 l/s is set so that dT5 is achieved with 5kW of heat transfer. This is because the heat capacity of water is about 4.2kJ per Kg (or litre). The heat transferred is then dT x 4.2 x flow rate, for example 5 x 4.2 x 0.238 = 5kW.
If you turned the flow rate down, then dT should in theory get larger since the two are linked by the above equation, but you may only see this in extremes when the heat pump controller is aiming to transfer the full 5kW of heat. Note, it can modulate down to about 1.4kW, which would give only about 1.5 degree difference between flow and return at the standard flow rate.
The shorter run times in mild weather are likely simply because your house doesn't need much heat and there are limits to how low the heat pump can modulate to before it has to start cycling.
I'd be inclined to live with the system as it is for a full season and then reflect on overall performance. If you are making home improvements such as the extension with underfloor heating, then perhaps that is the time to upgrade to larger radiators. Long term that's going to give a more efficient and somewhat smoother running system, but of course at a price.
The other thing to look at is have you done everything that you reasonably can to insulate the house? For example 300mm loft insulation, underfloor 150mm Rockwool insulation if you have suspended timber floors and enough access space, and high performance glazing. If your double glazing is fairly old, but the frames are still in good condition, then it is possible to retrofit Planitherm One double glazed units with warm edge spacers (U-value 1.0) into the existing frames. This is about 20-25% the cost of complete new windows, and greatly reduces the heat loss compared to older glazing, which may have a U-Value of 2.5.
If you increase the amount of insulation, the radiator output becomes larger compared to the heat loss figure, which lowers the maximum flow temperature needed, which lowers bills through both higher efficiency and less heat needed in the first place.
Page 2 / 2
