Why are DNOs replacing 100A household service fuses with 80A?
17 Users
31 Reactions
(@etchedpixels)
Your energy: 74 kWh
Posted by: @john-marshall
It’s a good job my partner didn't have a 60-amp supply, or Octopus wouldn't have been able to put an air source heat pump straight in without a DNO upgrade.
She has an 80-amp supply. Once you add up her 10.5 kW electric shower—which she uses for half an hour when she washes her hair—an oven and hob drawing 2–4 kW (allowing diversity), plus everyday bits like the microwave and toaster, you’re already pushing near 60 amps before the heat pump even kicks in. In a busy family home, expecting people to micromanage time when they cook or shower just isn't realistic — and at the moment she can afford to pay a plumber to convert to a cylinder-fed mixer shower straight, let alone buy expensive solar panels and batteries to ease the load. Off course costwise an electric car is just off the grid😊.
I think a 100-amp single-phase supply should be the standard for modern homes(unless of course 3 phase is installed)
with 80 amps as the absolute minimum — 60 amps is just too low. With millions of homes moving to heat pumps alongside megawatt-hungry AI data centres draining power, the National Grid will needs serious upgrading at some stage and ordinary households shouldn't be left behind. And when it comes to costs, eventually we're going to be paying for the grid upgrades I guess anyway and I'm sure those AI centres won't be left behind in the process. They'll have ample supplies probably with ample headroom. So when it comes to homes, I'm all for electic diversity/calculations but I'd err on the side of headroom.
I have a feeling it would probably be cheaper to round up all the 10kW electric showers in the UK and burn them in a big bonfire then give the users free sane water heating systems (even for hard cases) than do the local grid upgrades.
The UK 80-100A setup is actually rather generous by most national standards and heatpumps don't really make that much difference. For a decent 4kW heatpump you are pulling maybe 1.5kW on a cold day so it's a measurable baseload but not a huge impact. Car chargers and battery systems all know how to keep the house draw within the set limit.
Many countries you actually pay a premium per day on your standing charge equivalent which is based upon your allowed connection maximum so a lot of people only have 6 or 9kVa max (and also standing charges way higher than the UK as they more honestly reflect actual costs).
There are no AI data centres in the UK and no credible plans for them either at this point. One of the good things about our electricity price is its a very effective repellant for energy hungry stuff. Unfortuntely that also happens to be true for useful energy hungry things as well. Fingers crossed the AI bubble will explode messily well before UK power prices are under control.
Your energy: 179 kWh
@john-marshall
Have you looked at the actual power draw as opposed to a theoretical calculation.  If not you may be surprised by how low it is or how short any peaks are (this is relevant because the service fuse is slow blow).  Diversity really is a thing!
(@old_scientist)
Samsung
Your energy: 46 kWh
My heat pump installer conveniently glossed over my 60A fuse, and then failed to notify the DNO that they had installed a heat pump. Like you, we also have a 9kW electric shower, double electric oven etc.
I notified them shortly afterwards and NG promptly came out and upgraded the fuse to 80A. They were really helpful and supportive over the phone and by email. Luckily nothing other than a fuse swap was required which took less than 5 minutes.
This post was modified 2 hours ago by Old_Scientist
(@majordennisbloodnok)
Mitsubishi Electric
Your energy: 57 kWh
Posted by: @etchedpixels
Um, actually no. In fact there are 9 operational and another 3 planned. They are:
  • Isambard-AI & Dawn Supercomputers in Bristol (20MW)
  • NVIDIA Cambridge-1 Supercomputer in Harlow (1MW)
  • Two Google facilities in London (London AI Data Centre Europe-West2 and Google DeepMind - London AI Research Cluster) (260MW)
  • One Amazon Web Services facility in London (EU-West2) (400MW)
  • Microsoft Azure - UK South Region in London (500MW)
  • Rolls-Royce SMR-Powered Data Centre Initiative in London (470MW)
  • Digital Reality UK AI Mega-Campus in London (300MW)
  • CoreWeave UK AI in London and Manchester (150MW)
As you can see, that gives a total of 2.1GW capacity. That breaks down into 1.3GW already operational and another 770MW in the pipeline.
No disagreement from me there, though. Absolutely behind you there.
This post was modified 2 hours ago by Majordennisbloodnok
Your energy: 143 kWh
Hmmm. I see the situation differently.
Firstly a data-centre wouldn't be buying electricity from the wholesale market. It has predictable constant demand which it can satisfy by Power Purchase Agreements arranged with a portfolio of generation sites.
Secondly there is a plan in progress for a large AI data centre in North Devon. Xlinks are proposing to build a cluster of five 'cathedrals' with a combined demand of 1.5GW. Their Devon Data Campus is projected to be constructed on high-ground across agricultural land north of Great Torrington.
Adjacent to the data-centre buildings themselves, Xlinks plan to have a Battery Energy Storage System (BESS) with a 1.8GW connection to the 400kV Transmission Grid. They're unlikely to be worried about the size of the Service Fuse.
There is a local opposition organisation, Devon Data Centre and BESS Action Group whose website contains numerous fact-sheets explaining the technology and effects on the local economy.
BoundaryB13 Md520
This is the same area of the West Country where a number of renewable energy generation sites were required to abruptly cease export to the grid on Friday 15th May'26.
There was insufficient Reactive Power Compensation available west of Boundary B13. Reactive Power support is the grid feature which NESO requires in order to maintain control over voltage.
The generation sites weren't permitted to restart until mid-September, which cost them several £million of lost revenue.
See online article by Dr Simon Pirani.
Data Centres can't provide Reactive Power Compensation to the grid
Can we come back on-topic before I blow a fuse?!
This post was modified 14 minutes ago by Transparent
This post was modified 12 minutes ago by Transparent
Page 8 / 8
