Why are DNOs replacing 100A household service fuses with 80A?
Posted by: @old_scientistOne wonders what things will look like once 50% or more of households are fully electrified (hopefully those with such insight may be able to share their view)
Hopefully before we get there someone at DESNZ and Ofgem will take a look at what's happening down at the local sub-station level and realise the problems they're making by creating regulatory policies based on national statistics.
It not just the general public who need educating!
Posted by: @editorcould you say a bit more about bringing the voltage we actually get at home closer to 230-235 V? I can see how that might help with the high voltage cut outs Andrew’s been seeing. I’m curious what it would mean for the headroom on an 80 A fuse if you’ve got the heat pump running and the car charging at the same time. What would households gain from a wider reduction, and where might it cause problems?
Yes, it's time I addressed this voltage-lowering strategy.
It's going to be confusing to the public because some appliances will draw less power whilst others won't.
Let's start at first principles:
If I have a storage battery with a grid-connected inverter and I wish to export power to the grid, then the inverter must raise its output voltage:
Conversely, if I wish to recharge my battery, then the inverter lowers the voltage at its grid connection until the desired amount of current flows in the opposite direction.
However, the grid isn't an infinitely large ocean into which we can dip our buckets and remove water.
When I import power to recharge the storage battery, my inverter also pulls down the voltage on the supply to my house.
Here's a timeline showing three LV grid-monitors last night (1-min granularity)
Green and Purple are a matched pair. Green is recording the voltage at the incomer to the home. Purple is within the house, looking at the voltage on a ring-circuit.
The Peach monitor is on a different substation about 5 miles away, but both local substations are supplied from the same Primary Transformers.
The fluctuations around midnight are the normal pattern you'd expect to see on the grid. They're due to NESO bringing commercial generation and storage into use in order to maintain the frequency at 50Hz. As demand increases the line voltage falls, and the Operations Room brings more generation on-stream to match that demand.
At 00:30 a domestic storage battery starts being recharged. The voltage drops.
Since other houses connected to the same Primary will also start charging EVs at 00:30, NESO detects the additional load and adds generation from that being held on stand-by.
The (soft-start) inverter gradually increases the charge-current over 7 minutes. At 00:37 the green and purple monitors diverge. The inverter is close to the incomer, shown in the green trace, whilst the overall household voltage (purple) is reflecting that drop in supply voltage.
Although the household on the Peach monitor isn't charging anything in the home last night, it can still see the voltage fluctuations on the area grid.
At the top and bottom of the timeline are two pink-shaded areas. Those are outside the statutory envelope of the voltage as defined in Section 29 of the Electricity Safety, Quality and Continuity Regulations (2002):
The LV specification declares the Designated Voltage is 230v AC, from which it may vary +10% (253v) down to -6% (216.4v).
In the following timeline, the Brown monitor records solar-generation exceeding these limits. The solar-inverters in the area respond by cutting export and the voltage quickly falls.
Generation which is connected to the grid using inverters is based on electronics which can respond very fast to the limits imposed by the G98 regulations to which they must be certified.
That's a problem. When the clouds part and sunlight streams through, every solar-inverter in the local area will suddenly export power to the grid. Over-voltages are inevitable.
I'm going to pause at this point to allow others time to comment.
The explanation will be picked up again later.
Posted by: @agentgeorge@ronski your mixing kW values, which i see countless times in the forum
Mixing kW and kWh is something that bugs me, so I'd be very surprised if I got it wrong. Having checked my post above there is not a single issue with kW and kWh, yours however is littered with errors, which I've highlighted for you. It is not something I'd usually do, I'd usually just ignore the mistake, but seeing as you've decided to mark my work, I'll mark your's for you, and I give it a 1 out of 10 score 😉
For your information an appliance rated at 3 kW, but run continuously for 1 hour would have consumed 3 kWh of energy. (not taking into account fluctuations of voltage etc).
However if there is a mistake I've failed to see in my post, by all means point it out.
an EV is typically 51-80kWh and charges depending on the charger built into the car, early Leafs were 3.6kWh, most cars are 7.3kWh, the lucky few are 11kWh and will benefit from 3 phase power and a 22kWh wall socket, which you can have a dual one, so that blows the 19.2kW fuse restriction on a single phase.
A Heat Pump is rated like its previous heating apparatus, The Gas Boiler, on its thermal capacity. For a Gas Boiler 28-32kWh, for a Heat Pump, mine is 5.6kW, but only consumes 1.6kWh at full capacity frosty morning. During the day it hums at 600Wh
An oven has a heating up power of 3kW only for a few minutes, then hums at 500W every now and then.
A kettle is on for 90 seconds and modern ones are 2.3-kW
My Hob is the big guzzler, on Power Boil it can pull 9kW but only for a few minutes then it automatically turns itself down.
PV is also rated at its max production value, on a sunny day in the Midlands Ive seen 5kW from mine. This morning I have a splendid 100W. The output from the PV is limited by the Inverter, mine is 3000W, and any change to a higher one has to be approved by DNO.
My PV Battery has a max charge rate of 3kWh
I took some pictures this morning of my incoming grid connection, this is after 45 minutes of drawing an average of 15.5 kW. You can see the cable is 35.4°C.
The cable coming out the DNO fuse holder is 44°C.
So I really would not want to be pulling even more power than what I am for a sustained time.
@transparent I'm on Agile Outgoing so I actually tend to export between 16:00 to 19:00 down to 40% battery, then between 19:00 to 23:25 to 15%, but this time of year there is not much to spare, and most of the 40% to 15% is used in the house.
Eeek - those heat-maps are seriously uncool @ronski
Do you happen to know the size of your incomer?
I'd expect to meter tails to be 25mm². Are they?
It's slightly ironical that there's a heat signature around the LED indicators at the front of the Smart Meter !
I'm assuming you're in the North of England or Scotland. That meter looks like it's got an Arqiva connection.
The only markings on the incomer that I can read are 600 / 1000v Pirelli Gener, after that the cable goes into the DNO fuse housing, there is a sticker on the board that says 2 core supply and the cables OD is 19.6mm. The estate was built in the seventies.
I do have a PDF of my immediate area supplied by UKPN about four years ago, and that shows 2c 25W (Y), which implies its 25mm² two core cable on the yellow phase.
I'm in the southeast, and the meter is a Secure Liberty 100, the meter tails are 25mm², as is the cable out to my garage, where my inverter is and the cable back to the CU, all updated/replaced four years ago.
The above pictures shows the two 25mm SWA 3 core cables, the lower hotter one goes out to the garage, the top one is the return, which goes to the CU. The big power draws are all taken off in the garage, so the inverter charger, EVSE and ASHP are all powered from the garage. Ambient in our house is 21°C this time of year.
The temperatures are really not cool, but well within safe operating limits, I suspect there are a lot of cables getting a lot warmer, especially those that fully utilise their 100A fuses.
Currently viewing this topic 2 users ( Mars, Transparent ) and 8 guests.
Recently viewed by users: Ronski 52 minutes ago.
- 2,838 Topics
- 67.5 K Posts
- 1,142 Online
- 7,259 Members
