Replacing an old Fronius IG 30 Inverter
I have a 2.66 kW array on my house served by an old Fronius IG 30 inverter. Its near the end of its life and Im tempted by the newer more efficient options. I just bought a Solis S6-GR1P2.5K-M, partly for the increased efficiency and partly because I can add optimisers to it and link to Home Assistant. The original array is split into 2x7 panel strings which are connected in parallel inside the Fronius. However the Solis doesnt have this functionality and will have to be combined outside the inverter using a combiner box. Im looking for a cheap solution to this. ChatGPT thinks the panels are one of these. Unfortunately they dont have a label anywhere. There are many on ebay such as this one. Is there anything in particular I should avoid? Thanks
10kWh DC coupled battery
Currently viewing this topic 1 user ( bontwoody ) and 1 guest.
Recently viewed by users: Majordennisbloodnok 2 minutes ago.
- 2,823 Topics
- 67 K Posts
- 2,188 Online
- 7,243 Members
I have a 2.66 kW array on my house served by an old Fro...
By bontwoody , 5 minutes ago
I've recently has a new Cozy12 heat pump installed by O...
By dspillett , 16 minutes ago
@batpred divide by 2900 I believe. So you could try 24...
By AndrewJ , 44 minutes ago
@mk1234 The cycle is only on for 1 hour which is suffic...
By AndrewJ , 1 hour ago
By Majordennisbloodnok , 18 hours ago
By Transparent , 21 hours ago
By Singlespeed , 1 day ago
By archway , 1 day ago
By IanWilson , 2 days ago
By MikeH , 2 days ago
By mk1234 , 2 days ago
