Samsung HT Mono 8 kW air source heat pump overshooting room temperature after adding underfloor heating
Hi All,Â
Feeling pretty lost and confused and would benefit from some guidance. Â I had a Samsung HT Mono 8KW installed in late 2024, which included new radiators for each room each with TRVs. Â We've been on Octopus cozy ever since and ran our controller as a single central thermostat. Â We do not have DHW turned on as we have solar panels and an Eddi diverter, which is programmed to boost the immersion each day in the cheap lunchtime period. Â We had a heat survey done at the time by the installer, and we were a 3 bed-semi detached 1960's with retro-fitted cavity wall insulation, double glazing and a terrible single brick thickness single story utility area. Â
We recently had an extension built, so we are now a 4 bed, and have essentially replaced two walls of the house with modern building materials and insulation. Â We also dug up 2/3rds of the downstairs flooring and installed wet UFH in screed.
Previously we ran the heating only during the 3 cheap slots on cozy. Â However with the underfloor heating we were advised by our plumber that holding a single temp all day, with maybe a boost during the cheap periods and reduction during the expensive 4-7 period would be most efficient. Â
We therefore have tried to keep the house at 18 degrees, boosting to 19 in the cheap periods and dropping to 16 to get through the expensive period.
However my electricity use so far this month has been just shy of 700KW, and my heat pump, when running, is rarely less than 2.5KW peak power. Â Not only this, but the house is regularly exceeding 18 degrees, often hitting 20, and the heat pump just keeps going. Â I have included some images of the heat pumps power usage (in purple, the blue is the Eddi each day) from yesterday as a close up and the last week as a whole. Â I've also included my energy totals daily for the last period I have data for, and an image of my controller showing a set temp of 18 but a room temp of 19.9 (it had peaked at 20.4)
My understanding was that the heat pump would trundle along at maybe 1-1.5kw, rising slightly in colder weather? Â Also, I have no idea why it keeps overshooting my set temperature by so much.
I have very little understanding at the moment of the various settings in the controller and whilst I've been watching videos and trying to read other posts, I'm just not sure where to start, if my current set up needs changing, or whether my expectations have just been wildly wrong!
I really would value any help in starting to get to the bottom of this and getting a hold of my energy usage!
Posted by: @drgWe also dug up 2/3rds of the downstairs flooring and installed wet UFH in screed.
Was it insulated beneath?
Can you tell us more about the house, area, construction, assessed loss. Also what are your weather compensation settings and is there a mixing valve for the UFH or is it operating at the temperature of the flow from the heat pump. Is there a buffer?
- 2,837 Topics
- 67.4 K Posts
- 2,376 Online
- 7,257 Members
