If you were installing your heat pump again, what’s the one thing you’d change?
If you could go back to the day you accepted your heat pump quote and decided to proceed with the installation, what’s the one thing you’d do differently? What would you change? It could be where the outdoor unit went, which radiators you kept, or something you wish you’d asked before signing.
Generally there are only a few minor things,
Our North facing unit probably defrosts more and misses out on direct winter solar warmth compared to a south-facing one, it's out the way visually though.
Outwith my control, but this house really would have suited better from UFH downstairs rather than radiators.
The lounge is undersized, but managable, and i could get some skirting board pipes to a new second rad.
Edit: +Anti-freeze valves rather than Glycol, will convert at some point, as the pump never really stops running in the winter i don't see the need for glycol.
Should have installed the new one a year earlier, instead of waiting for the antediluvian ground source heat pump to blow up mid December 2025 🤣
If I were doing it again, I’d ask the installer to walk me through the system design before I signed anything. How would it keep every room warm on the coldest days it was designed for? Were the primary pipes to and from the heat pump big enough to carry the water flow the house needed? Ours weren’t. That’s the first thing I’d want to get right.
I’d also ask the installer to set up weather compensation and show me how to adjust it. We ran at a fixed flow temperature for two years before we’d even heard of weather compensation.
Possibly no glycol and anti freeze valves instead. I am delighted with the performance of my Ecodan but it is a condition of the Mitsubishi warranty that glycol is used. Given that the unit is now 7 years old the diamond warranty provides great peace of mind and flawless running 24/365, if at a cost. The installer did say that not much can go wrong with the Ecodan but when it does it comes with multiple zeros. I am now beginning to explore the upgrade route as after year 10 Mitsubishi don't guarantee to hold all the spares. Can the R290 unit be swapped in? Can the FTC be upgraded? We tend not to think about what comes next in the rosy flush of the newly fitted HP.
More fancolis (I specified 1, I wish I had specified 3). Otherwise nothing.
- 2,835 Topics
- 67.4 K Posts
- 1,597 Online
- 7,256 Members
