Seriously consideri...
Seriously considering switching to an ASHP but...
11 Users
18 Reactions
(@keithb)
Your energy: 4 kWh
I installed an ashp 2 years ago. Struggled to get it to work reasonably and reliably. Wont bore you but would go back to a boiler if it were viable. Just increasing another radiator size as cant get the lounge to get to 21 unless I wait about 4-5 hrs. I had to switch on climate control this winter as last winter bills were awful £340pm nov-mar. Pre heat pump gas/electricity £180max same period. Climate control switched on reduces bills to around £260pm but got to tweak more as I know if flow temp were 45 when around zero outside it would cope but current climate settings don’t allow it. Been absolute pain plus don’t believe noise ratings my max was said to be about 54 but when working hard (winter) I have recorded 63db. Just had a plumber to upgrade a radiator in the lounge he told me I am lucky many new builds he has worked in get electricity bills of around £500pm in winter. So much for economical. I also have solar and batteries but no help in winter with minimal sun!!
My experience
pick installation company that
guarantee's install
guarantees it perform to more agree temperatures
offer good loans
offer long warranties on all the system at least 7 ideally 15 on heat pump
secret an installer who really understands ashp fully and can assess then set up correctly.
offer annual service
Your energy: 30 kWh
Posted by: @domino
I'm not proud of my statement here.
Thank you for saying so. I and I am sure others appreciate you having the guts to say it.
Your energy: 137 kWh
Posted by: @domino
In fact, I see nothing preventing a self-install of an ASHP assuming that they have pre-charged condensers. The BUS grant just seems to get gobbled up by the installers anyway so apart from the physical grunt needed to get one of these things off the delivery truck to its final resting place, I see no difficulty plumbing in a flow+return and having a sparky connect the power. Must have been discussed somewhere around here already 🤔
There is nothing preventing A2W self instal apart from the electrical connection.  Several here have done it and, when it comes to a replacement, I probably will (if I'm still alive).  If you fit an umvented cylinder you need G3 qualifications, but that is potentially a separate job
Unlike a gas boiler where you need gas safe.
Posted by: @domino
Posted by: @domino
Frankly I find the suggestion of recourse to a 3-phase supply simply ridiculous just to accommodate a load which is probably less than one immersion heater.
I'm not proud of my statement here. I'm desperately trying to keep a level, balanced view and not come across as a selfish Mr. Angry. But this whole issue is proving to be a major stumbling block that I hadn't previously even considered
It's not unless you start off with an abnormal load or have a house loss more than about 16kW.  If you don't  fall into one of those categories forget 3 phase, it's an interesting (and ultimately possibly important) academic diversion but in practice not relevant at present.
In case you are in doubt gas prices are about to rise by 37%, electricity (only) 25%.  The electricity to gas price ratio will be 3.  At this point any heat pump that qualifies for BUS is cheaper to run and most half decent installs will be 25% cheaper, even if you haven't got solar or battery.  Which way do you think prices will go long term given that we can generate electricity from our roofs and wind farms we control, but inevitably import gas from America, the Gulf or Russia.  You can view what's currently happening as a taste of likely things to come or a blip.  Your choice!
This post was modified 2 minutes ago by JamesPa
This post was modified 16 seconds ago by JamesPa
Page 5 / 5
