Noisy Buffer Tank
I've recently has a new Cozy12 heat pump installed by Octopus. As part of the installation they installed a new 300L cylinder, a small Reflex 25L 4-port buffer tank and IMP Neo pump on the radiator circuit. My house is approximatley 200m2 with a heat-loss calculated at just over 10kWh. We have 19 radiators (all of which were changed as part of the install). The heat pump seems to be working well. I have no problem with the heat in the house, and the stats from the Octopus app suggest its working with a COP of between 3.5 an 4.2 at the moment. Given we've been down to -2C in the last week that seems OK to me. My question is more to do with the noise that's now coming from my airing cupboard. I would describe the noise as equivalent to what our old Grant oil boiler use to make when running. We also had a shower pump in the airing cupboard with the old setup and when the heat pump is working hard the noise is equivalent to the old shower pump. Clearly with the new ASHP running for long periods, it's making sleeping at night disturbed. Looking at the buffer tank it all appears to be plumbed correctly. The flows from the heat pump and out to the radiators are at the top and both returns at the bottom. The IMP Neo pump is set to auto proportional flow mode and does seem to adjust speed according to how hard the Cosy is working. So I don't think the installation has any issue. But I need to get this noise issue sorted. Could the problems be due to the buffer tank bracket being mounted on the plasterboard/studwork and the pump being very close and again next to pipework fixed with hard plastic brackets to the plasterboard? i.e. is the buffer tank acting like an accoustic amplifier and the noise of water flow and pump vibration being send around the walls? Would simply changing the mounts or placing some anti-vibration padding behind the buffer tank help? Or should I ask Octopus to come back and either remove the buffer or place it up in the loft where hopefully it won't be as disturbing? When it was being installed I did query whether I needed a buffer tank, as I'm well aware of the arguments against it and the potential impact on efficiency. I was told it would help with defrost cycles and given my high number of radiators (all on 10mm copper microbore) would help with flow rates.
I'd appreciate any advise and suggestions. Octopus are returning w/c 30/Nov so I'd like to have a good sense of what to ask them and understand what is acceptable as far as noise I should expect from this setup.
- 2,823 Topics
- 67 K Posts
- 2,186 Online
- 7,243 Members
Replacing an old Fronius IG 30 Inverter
I have a 2.66 kW array on my house served by an old Fro...
By bontwoody , 5 minutes ago
I've recently has a new Cozy12 heat pump installed by O...
By dspillett , 16 minutes ago
@batpred divide by 2900 I believe. So you could try 24...
By AndrewJ , 44 minutes ago
@mk1234 The cycle is only on for 1 hour which is suffic...
By AndrewJ , 1 hour ago
By Majordennisbloodnok , 18 hours ago
By Transparent , 21 hours ago
By Singlespeed , 1 day ago
By archway , 1 day ago
By IanWilson , 2 days ago
By MikeH , 2 days ago
By mk1234 , 2 days ago
