I'm planning to buy a large Victorian semi next year. It has all the usual issues: solid walls, high ceilings, single glazing and no insulation, apart from a modern kitchen extension. So, I'm budgeting for a substantial green refit before I move in, and this will include insulating walls, floors and replacing the 22 year old gas boiler with a heat pump.
Downstairs will be entirely UFH - the modern kitchen extension is already UFH, though designed for gas. it currently has 2 separate loops. After refit, the other two large rooms and hallway will also be UFH, with another 3 or 4 loops added, so 5/6 loops in total. total floor space is approx 110 sq m.
Upstairs there are two floors and 8 rooms, which will have new rads plus primary pipework. Total floor space upstairs is about 200 sq m.
1) Is it a crazy thought to specify a dedicated heat pump for the ground floor UFH? This would allow it to run at low temps without needing to serve higher-temp rads, or the hot water tank. A second heat pump would be allocated to the upstairs rooms and hot water.
2) Could there be any problems with the UFH pipe spacing in the kitchen being too far apart or too small for a heat pump, given it was designed for gas originally?
3) is anyone using an under-counter water heater in the kitchen? Given the desire to have the main water tank at lower temps (e.g. 45 degrees), I've always thought this was too cool for dishwashing. I thought a water heater might be a neat solution, though perhaps there are big drawbacks?"
