How to seal a drain...
How to seal a drain for r290 regs
1 Users
0 Reactions
(@falesh)
Your energy: 9 kWh
Topic starter   [#3240]
I've just had an installer come round and the only place that can work for the heat pump is near this drain. Because the heat pump has r290 the regs say it needs to be sealed. Does anyone know how I would go about sealing this while still being able to remove leaves and debris from the drain?
(@falesh)
Your energy: 9 kWh
Also, would it be possible just to increase the height of the drain and still have it open. Like building a mini wall around it. Would that make it higher than the pooling r290 would go? This all seems a bit silly for such a small amount of r290, but hay ho.
