Home batteries for time shifting and backup – exploring the current state of play
I guess I'm frustrated that I can't buy a decent 8kWh battery off the shelf for c.£1,200, despite there being decent 16kWh batteries for £2,000-£2,500.
Let me provide three actual examples of batteries in that price range.
I'm also deliberately picking up a point previously made by @jamespa who commented on the possibility of stacking batteries above each other on a wall.
The Chinese manufacturers have for too long been offering a horizontal battery enclosure like this and then standing it upright.
The problem with that becomes obvious if you wish to bolt a battery to the wall above it. The LCD display, terminals and isolator switch would be facing vertically up towards the base of the upper battery.
That price includes VAT and carriage. It's UK stock and gets delivered within 5 days.
Here's another example, this time using slightly higher capacity cells to achieve 16kWh:
Eco-Worthy is a well-known brand, and is also supplying from a UK warehouse. They use a Pace BMS unit internally, which is regarded as reliable.
Unlike the earlier 15kWh battery from SJY, Eco-Worthy only has one pair of high current terminals. If you wanted to install two or more units, then you need some busbars to combine the high-current cables before connecting to the inverter(s).
If you'd prefer to assemble your own battery, then JiKong can supply this vertical enclosure, which they ship from China. As there's no cells yet installed, it can be shipped air-freight. You then source the cells separately.
Self-assembly makes sense if you want to stipulate a particular manufacturer of the cells, which will come with a guarantee of their rated capacity. This enclosure can accept cells whose capacity might be 280Ah to 314Ah. Those are the same physical size.
It's also much easier to fix an empty enclosure to a higher position on the wall if it doesn't already have 100Kg of cells inside it !
Jikong are better-known for their JK BMS modules, and this battery kit includes their Smart 200A model.
I'm unsure if these low prices are only valid during this Black Friday week. It would be risky for the vendor to attempt raising the price again at the start of December because rivals might keep their prices low.
This post was modified 12 minutes ago by Transparent
