Grant Aerona 3: Recommended Water Pressure
Hello. We got up this morning to a cold house and haven't worked out what the issue is/was. The programmed settings for heating were all correct and it should not have been 12.8C!! The time and date on main controller wasn't set and was maybe lost in a power cut (we have been away) but on the portable controller downstairs is fine. I have reset that so let's hope that works. However I did not notice that the water pressure is a bit below 1 bar and there is a red arrow set at 2 bar. Should I be filling the system up?
I'm surprised it cuts out at this level but yes, fill the system to say 1.5bar. Also check what pressure the heat pump thinks it is seeing (somewhere in the UI I expect).
It could also be a blocked filter between the system pressure gauge and the heat pump. If filling the system doesn't clear the fault suspect that. There are often 2 filters, a magnetic filter first and then a gauze filter. I have a feeling that the latter is inside the Grant, alternatively it may be nearby but outside the ODU, on the return.
@davidm06, I’m with @jamespa that around 1.5 bar with the system cold sounds like a reasonable starting point, although I’m not sure there’s one universal figure for every installation. Our original system was always filled to 1.5 bar, but the last two installers we’ve had were adamant it should be 1 bar, so we’ve certainly had differing advice ourselves. The black needle in your photo does look just below 1 bar, but the red pointer is simply a reference marker, so its position at 2 bar doesn’t mean you should fill to that level, and you can move it to 1.5 if that’s the cold pressure you’re aiming for. I'd watch it over time. If it drops over a few days/weeks, that may be indicative of a micro leak somewhere. Also, bleeding rad and towel rails that have air in them drops the pressure.
That said, I’d be interested to know whether resetting the clock has brought the heating back, because we haven’t yet established that the pressure caused the cold house, and personally, a reading just below 1 bar wouldn’t be my first suspect for a complete loss of heating.
- 2,827 Topics
- 67.1 K Posts
- 1,185 Online
- 7,246 Members
