Vaillant ecoTEC Plu...
Vaillant ecoTEC Plus - Flow Temp and Set Up
3 Users
4 Reactions
trebor12345
(@trebor12345)
Your energy: 8 kWh
If you extrapolate the heat curve you posted linearly it hits 29 at 2.5C at which point it will flatline because you have (apparently) set 29 min.  I dont know that its exactly linear and nor do I know the precision with which it adjusts FT.  I would guess it might be 0.1C but its just as likely to be some odd fraction that works out well in binary, or even 0.5C.  I also dont know the precision with which it measures flow temperature.  Until temp falls below zero for a few hours I wouldn't be worried if I didn't see a change other than in  compressor modulation depth which will respond to demand.
I think I have better handle on this now.  Because my system is sitting on a 29°C minimum-flow-temperature floor at around 2°C outside, the compressor is increasing output instead. As the outside temperature stays colder and the curve's target rises above that floor, I should eventually see the flow temperature rise.  There will always be delays/misalignments as it adjusts so the relationship will not ever be perfect unless OAT stabilises for a long period of time.
Now wait and see what happens.
Vaillant aroTHERM plus 3.5kW
50 litre volumiser
3.6KW solar panels
Tesla 13.5kw Powerwall 3
Page 3 / 3
