Heat Geek installat...
Heat Geek installations: share your experiences
7 Users
5 Reactions
Topic starter   [#3185]
We have dedicated forum threads covering many of the UK’s major heat pump installers, so it’s only fitting that we have one for Heat Geek.
If you’ve had a Heat Geek installation, please share your experience, good, bad or somewhere in between. We’d particularly like to hear about the design and quotation process, installation quality, disruption, promised and actual performance, flow temperatures, aftercare, performance guarantees and how any problems were resolved.
The aim is to build a fair, balanced and useful discussion based on genuine homeowner experiences, helping others make better-informed decisions.
Please keep contributions factual and respectful.
Topic Tags
(@batpred)
Posted by: @batpred
Posted by: @l8again
I was told that installer doesn’t get to see the system design temperature until commissioning is complete. I can live with that given the minimum guaranteed SCOP. My minimum SCOP is 4 and earlier this year my system was happily chugging along at a heating curve level of 0.2.
That was similar with us (on the design temperature), we noticed that there was no design temperature shown in the earlier documentation. We are happy with our guaranteed SCOP (including hot water) of 3.75.
The commissioning survey did show a design temperature. But to be honest, since not all the rad upgrades were registered (we had our own plumber doing some of them), I expect that it was over estimated.
But reading the posts here, i am being picky. The whole process was pretty smooth, plenty of post commissioning docs with photos etc.  Given how much care our Heat Geek took to install original Vaillant wall brackets (suitable for external insulation - a very elegant finish), I doubt MCS could find any gap anywhere. HG handle all the overheads very efficiently..
Of course our pump has only done hot water and cooling so far..
My summary, highlighting the oddities.
I received a very interesting email from a homeowner today which raises another question about going through Heat Geek’s platform versus approaching an installer directly. I’m keeping the homeowner and the installer anonymous, and I’ve rounded the figures slightly up and down to protect their identity, but the amounts remain very close to those in the email.
The homeowner is looking to replace an old heating system with a heat pump and a new radiator system, and Heat Geek had pointed them towards an installer. Going through the platform produced an online estimate of around £7,200, with a survey fee of roughly £300 and performance guarantees, whereas approaching that same business directly through their website produced a much more detailed estimate of approximately £11,800, with a survey fee closer to £400. Neither route has yet involved a visit to the property, so these are preliminary estimates, but we’re still talking about nearly £5,000 between two routes to the same installer for the same house.
My immediate suspicion is that the lower figure reflects a ZeroDisrupt ‘package’, while the installer’s direct estimate allows for a more extensive retrofit.
And that is where I find the situation rather bonkers. If the installer considers the more extensive work necessary when approached directly, could that same installer then arrive to deliver a reduced specification because the customer booked through the platform? If the additional work is optional rather than necessary, why isn’t the homeowner being shown what it would achieve and given the choice? The house hasn’t changed because the enquiry arrived through a different website, and the professional judgement about what it needs shouldn’t change either.
A cheaper installation isn’t automatically a worse one, and a higher price doesn’t prove that somebody is doing the job “properly”, but the distinction between essential work and optional improvements should be crystal clear. There’s a perfectly sensible conversation to be had about spending more upfront for better performance, less noise or a preferred equipment location; there’s a much less reassuring conversation where the homeowner cannot establish whether the cheaper offer includes everything needed to do the job in the first place.
What makes this particularly telling is that the homeowner actually trusts the higher estimate more because of the detail it contains. They aren’t demanding the cheapest possible installation or accusing anyone of overcharging… they’re simply trying to understand what they would receive.
Has anyone here obtained prices through both routes and had the difference properly explained? Same house, same prospective installer, nearly £5,000 apart…
(@andrewj)
Octopus Cosy
@editor I suspect that the Heat Geek online quote is a marketing hook only.
When I first contacted HG their on line quote was based on an EPC rating, house age plus details of number of bedrooms.  They quoted me a 10kW Vaillant, 250L tank and up to 3 radiator changes, and I presume the labour and additional gubbins such as expansion vessel, volumiser, piping and fittings, controller etc.  The quote was £8.5k.  The installer came around and said we’d only need a 7kW Vaillant but all 16 rads would need changing (which I knew). His quote was £18.5k.  It’s worth mentioning that it isn’t/wasn’t a complicated install - the airing cupboard was big enough for everything with room for shelving, pipe run was very straightforward, radiators all replaced in-situ so no re-piping.
It struck me that the changes from the online quote to the actual quote were a smaller heat pump, an additional 13 radiators and, probably, 10m longer pipe run from the external unit.  I don’t know for sure of course, but I thought that the extra copper wouldn’t have been much more than the price difference between a 7kW and 10kW Vaillant so the extra £10k was being taken up with 13 new radiators.  The install duration was quoted at 4-5 days at £9k labour.
I didn’t go with HG for obvious reasons - £26.5k before grant to upgrade a heating system without complex problems is clearly nonsense - but I felt that the initial quote was totally irrelevant.  I tried to get to the bottom of the difference but no one was forthcoming, just a generic “things can change once the survey is done”.  I complained and got my survey fee back.
So the online price is just a hook in my view and in your example, it’s probable the installer was being more realistic.
(@l8again)
I struggled with this problem as well. An independent told me that I would need a new cylinder and a buffer tank as my property has 10mm PLEX piping. The quoted priced reflected what was proposed.
Hest Geek Zero Disrupt can back with continuing to use existing cylinder and no buffer tank. Yes, I decided to have 8 radiators moved (including 5 new ones) and the total cost to me was £3000 with a guaranteed minimum combined efficiency of 400%. (I was told not to use SCOP as SCOP is related to space heating only).
Chatting to my installation, they told me that for a bespoke installation all pipes under floors would be changed and fully lagged and they wouldn’t use Primary Pro installation. Yes, the installer concerned has one installation on OpenMonitor with a SCOP of 5.3.
As far as my installation is concerned, the system is totally silent. My house is at 22C and the heat pump has consumer 4kWh of electricity so far today (hot water and heating) with an overnight OAT of 6C either a combined efficient of 501%.
Are some installers taking customers for fools - my view is they are. In their defence, the installer who wanted to fit a buffer tank said he had no complaints from his customers about a cold house.
(@batpred)
Posted by: @l8again
one thing i learnt from reading people’s comments and experiences here is that tanks that have additional pumps are extra things that can fail. And when i had installers trying to convince me of the need for a buffer, it was obvious most did not even know the difference from a volumiser. And the fact that the goal of a volumiser is to reduce cycling.. plus these things always add to the cost, which usually means the price is higher.
(@ian-s)
I haven’t had my Heat Geek installation done yet but the journey so far is far from great. After the quote and design I asked a number of questions based on comments from experts on here, initially I received answers fairly quickly then on the last couple I got radio silence despite chasing and emailing Adam as he is always on YouTube. Still nothing but got traction when I left a poor review on TrustPilot, my contact was very apologetic and said he had been away and someone should have responded. He answered the final questions so I thought I would go ahead, paid the deposit and was told BUS granting approval was taking about a month at most. Over a month has gone so was about to chase when I get forwarded an email from Ofgem where the title included the word REMINDER! Heat Geek asked me to reply directly to Ofgem cc’ing them with the information requested which was a photo of our gas boiler and one of the boiler nameplate, it gave 14 days to reply or the application would be rejected!!!!!!
I have supplied the pictures to Ofgem but I followed it up with an email to Heat Geek asking what the hell is going on and why they hadn’t supplied all the relevant information as they should know what is required, I also raised why the email was a reminder.
Being brutally honest I am on the verge of telling Heat Geek to do one and forget about going for a heat pump as every company I have dealt with hasn’t filled me with confidence and if this is the level of service they provide what will happen if things go wrong. My gas boiler works, our gas engineer it trust worthy and knows their stuff. It feels like the heat pump world is like the Wild West.
Sorry for the rant but as it currently stands I could never recommend Heat Geek to anyone.
Hmmm
(@batpred)
Sorry to hear.
I had a very straightforward interaction with Ofgem.
Heat Geek are good at giving an idea of how long these processes that they do not control are taking (in my case approval of the new arotherm models by ENA). Probably something they can do better than most, given the large volume of installs that they handle.
I did find the heat geek interactions mechanical and my installer made it a much better experience.
(@etchedpixels)
It's heavily dependent upon the actual installers and I think they do seem to have some growing pains right now.
Our interaction was good. Initial look, pricing, and honest to tell us not to.
I would agree the air/water heatpump market is full of cowboys. The big grants, poor standards and ineffective regulation suck in all the people who do a course, slap a label on the van, chase the grants, rinse, repeat. It's no surprise that some of the heatpump installers used to do ECO4 EWI and before that spray foam. I wouldn't let most heatpump people anywhere near my house.
Aircon style is easier because many of the companies doing it are often 40 odd years old, their major customers are businesses and many of those businesses don't tolerate useless contractors particularly well. Even some of the one man aircon bands have been at it that long, just it was seen as a weird fringe business until last year.
(@l8again)
@ian-s I have said before that I found some of Heat Geek HQ’s administrative procedures somewhat opaque.
I also had a BUSGrant rejection from Ofgem as they concluded, I guess from misreading the EPC, that I might have had a woodstove with a back burner. The Ofgem rejection was forwarded to me by Heat Geek and I was asked to respond directly to Ofgem. This made a lot of sense as it was better for me to address the concern directly rather than passing it through HeatGeek.
I think what matters here is the bond of trust between the customer and the installer: that said, I had to keep reminding myself that my contract was with Heat Geek HQ - not with the installer. For example, I had some problems with the Primary Pro insulation splitting at the joints. Normally, I would have expected to deal with the contracted party but I knew that Heat Geek HQ’s response would be ‘contact the installer’. Fortunately, the installer was happy to return to address the problem.
Would I choose Heat Geek again? Based on what I am seeing from my heating system at the moment, my answer would be firmly in the ‘yes’ category. I am hovering between 0.35 and 0.4 as my final Heat Curve setting for a house with 14 radiators/towel rails and an existing Worcester Bosch 8 year old unvented cylinder with 12mm PLex piping. The latter two were big ‘no no’s in the last. My combined hot water and space heating efficiency yesterday was over 520%. The system is totally silent inside the house and the flow rate is 1157L/hr. As I post, with an OAT of 7.4C, the flow temperature is 31C. In sum, whilst Heat Geek HQ might not be as polished as I would have hoped, I cannot fault the Heat Geek design process; the minimum combined efficiency guarantee; actual system performance or system cost.
As an aside, I went round to a neighbour’s home yesterday to try to help with an internet issue. As she opened the front door, I was greeted with a blast of hot air. Her kitchen was unbearably hot. She said that her hall thermostat was set to 21C. I avoided telling her that my heat pump had consumed 7.6kWh of electricity the previous day for the same internal temperature.
@ian-s, I'm sorry to hear this, and I can understand why you're getting increasingly frustrated. Nobody expects every email to be answered immediately, and I appreciate that things occasionally get overlooked, but having to leave a negative review just to get a response, followed by discovering that Ofgem has already issued a reminder about your grant application, isn't exactly going to inspire confidence, particularly when you're about to spend a considerable amount of money and are relying on the same company to look after you once everything has been installed.
What's disappointing is that I'm hearing more stories like this. I've been receiving an increasing number of private messages from homeowners who've had less than encouraging dealings with Heat Geek, alongside some of the experiences we've seen shared on these forums, and I'm beginning to wonder whether the business has grown faster than its ability to look after customers properly.
They've put an enormous amount of effort into building the brand, but I wonder whether all that attention on marketing, securing investment and business growth has come at the expense of the rather less glamorous business of answering emails, managing applications and making sure people feel looked after. That's obviously just my impression from the feedback reaching me, and I'm sure there are plenty of satisfied customers, but it would be a real shame to see the reputation they've worked so hard to establish undermined by something as fundamental as poor communication and customer service. Please keep us posted, because I'd be interested to see how they handle this from here.
(@batpred)
I am curious as well. But not yet concerned about the solidity of the performance guarantee. They warrant 375 and we are currently getting above 400.
They are very competitive on price so I am actually surprised there's not a lot more bad mouthing going on.
Page 1 / 2
