Why are DNOs replacing 100A household service fuses with 80A?
1 Users
0 Reactions
Your energy: 34 kWh
Topic starter   [#3239]
We’re beginning to see more reports on the forums of DNOs replacing 100A service fuses with 80A ones, and I’m curious about the reasoning behind this when the wider push is towards electrifying our homes. From a homeowner’s perspective, being encouraged to install heat pumps, charge electric cars and move away from gas cooking while having the incoming supply’s fuse rating reduced feels a little counterintuitive, although I suspect there’s more to it than simply comparing the two numbers.
@transparent, you offered to explain how the grid is evolving, so could you talk us through how these lower fuse ratings fit into that picture and what homeowners should understand when planning their next steps towards electrification?
