[Sticky] Air source heat pump roll call – what heat pump brand and model do you have?
Samsung 16kw has been working well at home in Perthshire for the 1st year since commissioning, though made the error of turning things down while away for a few weeks over Xmas - which of course cost a packet to reheat the house and probably strained the kit a bit. Won't do that again, though we do keep heating off over the summer and will restart at end of August.
Have also installed Mitsubishi Ecodan in an old stone cottage on west coast of Ireland (Connemara) after renovations to insulate floor, install UFH, insulate and airtightness, MVHR, triple glazed windows etc. So far so good but can't quite understand seemingly high energy consumption in June when it was so mild there. Now also running only DHW as solar gain and insulation keep house warm (at lease during the heatwave in July). Will heat again from end of August. One niggle - tried to install the wifi unit (not standard it seems) and the MAC-5971F-E was a trial. Docs pointed to wrong app (MELCloud Home is the right one). Blutooth connectivity to start is an issue noted by MEL on their availability pages ( https://www.melcloud.com/en/support/service-health/service-statuses-table) as is availability of their servers! The last may explain why I eventually had to give up as the final registration step to those servers has not yet succeeded. Will try again periodically. A bit annoying after shelling out for the wifi unit but hey ho!
Unit is less than 100m from the sea so some trepidation about longevity and storm survivability tbh (having recently experienced some of the worst that the Atlantic can generate) but we'll see how that goes over time.
Mftr: Mitsubishi
Indoor Model: Ecodan EHST17D-VM2E
Outdoor model: SUZ-SWM40VA
Area: ca. 95m2
Heating: UFH throughout
Occupancy: normally 2, max 6
DHW: 4 sinks, 1 shower. - scheduled for 8hrs a day to see how it goes.
Forum Handle: adrian
Manufacturer: Appliandirect.co.uk
Model: Superheat R32 7kW
Type: ASHP
Arrangement: Mono
Area of Country: Schleswig-Holstein, Germany
Home Type: detached house
Size: Square Metres: 100
Insulation Level: 5
Heat Loss Calculation: 6kW @ Amb. Temp, of: -10C
Type of Controller: supplied with HP
Type of Control:, Weather Compensation
Very simple DIY install, got the heatpump refurbished from appliance direct for £568 and installed it with just the minimum components (1x anti freeze valve, y-filter, magnetic filter and expansion vessel). The house already had plenty of radiators as my dad had been told that you needed one under each window and was piped with 18mm copper pipes. Hot water is supplied by an electric instant heater. Total cost £1400.
We've had an influx of new members joining the forums over the course of the last few months so I thought it would be a good time to give our heat pump roll call a little refresh.
If you've joined us recently and haven't yet added your details, could you please take a minute to reply with the make, model and size (kW) of your heat pump? We're keeping an updated list of what everyone has installed, which makes it much easier to connect with other homeowners running the same equipment, compare experiences and help each other troubleshoot problems.
Just drop your details below and I'll add you to the main list.
@editor And as an occasional contributor, may I say welcome to the latest cohort to RHH!? The more systems discussed and problems shared, the more others may be helped with their own systems. A good job well done!😉 Regards, Toodles.
- 2,818 Topics
- 66.8 K Posts
- 3,275 Online
- 7,231 Members
By AndrewJ , 52 minutes ago
By Mars , 2 hours ago
By EtchedPixels , 3 hours ago
By Judith , 6 hours ago
By JamesPa , 9 hours ago
By JamesPa , 11 hours ago
By Mars , 15 hours ago
By hml1827 , 1 day ago
By bobflux , 1 day ago
By EtchedPixels , 2 days ago
