Why are DNOs replacing 100A household service fuses with 80A?
9 Users
14 Reactions
(@andrewj)
Octopus Cosy
Your energy: 34 kWh
@transparent sorry, my bad wording.  What I was referring to were the houses between me and the substation.  The engineer said that tapping it down would impact them too much.
I don’t know if neighbours have over voltage or even if they would know.  I can tell because my EV charger goes off-line so there is a visible indicator when it’s fancy LED turns red for a brief period.  If I check my inverter stats I can see the current voltage level.  As mentioned above this occurs during the summer months when the PV generation makes a sudden increase, e.g. sun comes out from behind a cloud.  I only have a 3.6kWh export allowance which the installer and I presumed was because of other PV installations in the area but if I think about it, they are all elsewhere on the estate.  I can’t think of any other houses that have PV that would be on my cable run given the direction it takes.  Number 9 doesn’t have PV but its cable does probably service houses that do as there is a cluster in that direction.
This is all great information.  I’m not really sure what I can be asking/telling NGED though.
Page 5 / 5
