Replacing oil heati...
Replacing oil heating in a 1600s cottage. Is a 12 kW heat pump enough and what should it cost?
1 Users
0 Reactions
(@eccentric-sushi)
Considering a heat pump
New Member Member
Your energy: 17 kWh
Topic starter   [#3242]
Hi,
We recently moved into a 1600s cottage (4 bed, 235m) which is timber framed with brick infill and wattle and daub throughout. Currently undergoing some renovations to the property to make it fit for purpose for the next 20 years or so. We have already put UFH throughout, and are upgrading the roof insulation and windows to double glazed. I am looking to upgrade from oil to ASHP. I did look at GSHP but the cost is too significant, and payback too late to make it worthwhile. Also installing solar on garage with battery so should be able to use renewable energy to power the pump (sometimes).
My question is what should a c.15-16kw heat pump cost to install given we already have UFH throughout (not screed - it's a warmup system with either foam or 22mm plyboard). We have a vented cylinder (I think) so will likely need a replacement. I presume I don't need Buffer tanks given the UFH.
Costs are varying from £3.8k (Octopus), £4.5k (OVO through a third party installer) and £6k (Glow Green). All for similar sized kit.
I have done my own heat pump calculations, but seem to be getting told I only need a 12kw heat pump (I think I need 15-16kw). The cynic in me thinks it's down to what kit the installers have/what's giving them the highest margin. What are the downsides if my calculations are wrong and others are right? I get you can end up with heat pump going on and off along with marginally higher heating cost, but will a couple of kw redundancy if the system is inadequate seems worth it in my mind?
The whole tinkering around with numbers to backfill the answer you want is echoing the EPC/home surveys of past, which do not give anyone any confidence.
And in terms of kit, anything you would/wouldn't recommend? Anything I should be looking out for? Any specific questions I should be asking? Valliant and Grant seem to be recommended quite a lot and I can see lots of pros and cons for each, but cons I am guessing are almost always due to poor install in the first instance.
We are based near Aylesbury in Buckinghamshire, so if you do have any recommendations for installers, I'd appreciate contact details.
TIA!
This topic was modified 7 hours ago 4 times by eccentric.sushi
This topic was modified 26 minutes ago by Mars
