If you were install...
If you were installing your heat pump again, what’s the one thing you’d change?
8 Users
2 Reactions
(@majordennisbloodnok)
Mitsubishi Electric
Your energy: 51 kWh
I’m similar to @etchedpixels. There are a few things I’d change about our setup if we were to do it again but nothing I’d’ve done differently - at least with the heating system.
With a magic wand now, I’d love to have an R290 system, antifreeze valves and no glycol but the R32 Mitsi with glycol was the right choice at the time and was installed well as part of an intelligently designed retrofit. All my niggles are because time and tech have moved on.
The only thing I’d’ve wanted different at install time was nothing to do with the heating engineers at all. It was the other company that installed our solar PV, and in retrospect we’d’ve done far better with a bigger battery and an inverter that could charge or discharge it at more than 3kW. Looking back now, that’d’ve made a big difference to our heat pump running costs.
Page 2 / 2
