Our 10 year old Grant heat pump failed
Posted by: @deltonaSo financially speaking you'd have been better off with a gas boiler 🙄
Initial outlay should be made up by lower running costs. At the moment, our leccy is 3.5/kwh and gas 7.. Before efficiency is considered.
Posted by: @mike-patrickThe above occured over several weeks during which I also sought quotations for a brand new system. To keep them all comparable I had restricted these to suppliers/installers of Vaillant units and on the basis that we would have a new water cylinder too. Our existing UFH pipework would remain. The quotes came in at from £11k to £14.5k.
But as @mike-patrick found, replacing a pump can easily hit the hurdle posed by the simple estimating approach that most installers are using.
Posted by: @batpredPosted by: @deltonaSo financially speaking you'd have been better off with a gas boiler 🙄
This thread is about Mike, my response was to Mike.
My Grant Aerona is 10 years old now and has been something of a money pit ever since.
The most recent problem was in February this year when it stopped working with a P1 error code.
Initially advised that I needed a new ASHP, a solution was eventually found that involved a new PCB and compressor at a cost of £2,000. This had taken until April given the difficulty of finding engineers who understood the problem. That is our second replacement PCB.
Everything seemed to be well. In May, as usual, I switched the controller to DHW only as the house kept itself warm enough without heating.
Fast forward to the end of September I switched the controller back to UFH as well and all seemed to be OK. But recently (to coincide with the later onset of cold weather) the ASHP has stopped responding to the controller calling for UFH and only comes on for the hot water. There is no error code and everything else appears normal, except we have a cold house.
We are back now where we were in February waiting for our local heating engineers (who were not the original installers but are Grant approved) to summon their one specialist (a sub-contractor) to diagnose and hopefully fix the problem.
With the temperature this week dropping below zero the heat pump has started to frost up when it's running. This means that it does a poor job of heating the water but uses a lot of electricity defrosting itself. I've switched DHW off and am using the immersion heater for the duration of the sub zero temperatures. It could actually be cheaper than the heat pump. So that's no UFH, no DHW.
Thankfully we have wood burning stoves to fall back on.
Not quite what the government was thinking of when encouraging us to be prepared.
Sorry to hear that. I presume you have checked the obvious things like filters, system pressure and any third party call for heat?
@mike-patrick, the past 15 months of problems with our own heating have really opened my eyes to just how important the controls are, which probably sounds bloody obvious, but I hadn’t appreciated how much thought has to go into making everything work together in a particular house, especially a retrofit. We’ve got underfloor heating, radiators and hot water, and once you start looking at which demand should start which pump, where the valves need to send the water and what should happen when the cylinder needs reheating, there’s quite a lot going on behind an apparently straightforward request for a warm room (which is not very straightforward). We’ve spoken to installers who are absolutely brilliant on the plumbing and hydraulic design regarding our own flawed system, but who need somebody else to work out how to wire and coordinate all of that, and we’ve repeatedly found ourselves in the situation where the pipework looks fine but nobody attending can explain why the controls aren’t doing what they should.
That’s why @jamespa’s point about the call for heat caught my attention, particularly as you mentioned earlier that it took a separate controls specialist to get a proper diagnosis last time. I’ve no idea whether controls are behind this latest problem, but given that the unit was still responding to a hot water demand while ignoring the heating, I’d want whoever attends to follow that heating demand through and establish where things stop happening as they should. Bringing in an electrical or controls specialist makes perfect sense to me, but having a cold house while everyone waits for the one person who understands how it all works is a pretty miserable position to be in, especially after you’ve already spent £2k getting it repaired.
A 10 year old grant heat pump dates from when Grant tried to 'add value' by taking a perfectly good third party pump and adding their own rubbish relay logic to make it look like a boiler. This may need to be checked, it could be something as simple as a loose connection!
There is nothing about central heating controls that anyone who can put together a sentence in English (or any other language) can't understand. Unfortunately we all too often make it more complex than we need to by having multiple controllers and then expecting them to cooperate, which of course they don't. Even then the average person can understand it if they choose to, but they choose not to. In addition to the efficiency arguments, this is another reason to reject third party controls.
The only other thing to remember, which I think caught your installers out @editor, is that we have traditionally used 240V logic in UK central heating, and that does not mix well with modern electronics!
@jamespa Yes, not me but the engineer who visited to make an initial inspection (he did fix a minor leak around a compression joint which I had reported a while back). He's reporting back to base and I'll then have to chase them to send over the controls guy (there is only one and he's "very busy") asap. With the instruction manual to hand I did check that the setting for weather compensation was set to Yes, which it was, But I don't know enough about all the settings to dive deep into the almost impenetrable Aerona control menus. I might make things worse.
Mike
Posted by: @mike-patrick@jamespa Yes, not me but the engineer who visited to make an initial inspection (he did fix a minor leak around a compression joint which I had reported a while back). He's reporting back to base and I'll then have to chase them to send over the controls guy (there is only one and he's "very busy") asap. With the instruction manual to hand I did check that the setting for weather compensation was set to Yes, which it was, But I don't know enough about all the settings to dive deep into the almost impenetrable Aerona control menus. I might make things worse.
Mike
As I understand it it was working then stopped. More likely a hardware/external control issue than something that needs reconfiguring.
- 2,825 Topics
- 67.1 K Posts
- 1,887 Online
- 7,244 Members
