To re-pipe or not to re-pipe? Moving from oil boiler to air source heat pump.
Installing ashp in early 2000 homes. We have a 2010 self build which we bought in 2013. Insulation is good but down stairs has a floating floor. We’re going to move from oil to ashp. We’re getting mixed messages about the existing system which is microbore pipes. Some advise ripping it out and re piping. It’s going to be messy. Others say that with modern ashp as long as the radiators are sized right it doesn’t matter. What is the right approach?
Welcome to the forum @penval.
The key thing to understand with heat pumps is that you’re no longer “blasting heat” into the house like an oil boiler would. You’re moving heat gently and continuously through water at a lower temperature. The entire system is designed around shifting a steady volume of warm water through emitters, rather than short bursts of very hot water.
Because of that, performance comes down to two things: how much heat the radiators can emit at lower temperatures and whether the system can move enough water to carry that heat around the house. In simple terms, the heat being delivered is a function of flow rate and temperature difference, so if you drop the temperature (which you do with a heat pump), you need sufficient flow to compensate.
This is where microbore becomes a consideration… not automatically a problem, but something that needs proper assessment. Smaller pipes can restrict flow, especially if runs are long or the system layout isn’t ideal. That can limit how much heat you can move, regardless of how good the heat pump itself is.
That said, ripping everything out is often a knee-jerk reaction. If the pipework is well laid out, circuits aren’t overly long and the system can achieve the required flow rates, microbore can and does work with heat pumps. The deciding factor isn’t the pipe diameter on its own, it’s whether the system can deliver the required flow at a reasonable pressure without causing issues like noise, imbalance or excessive pump strain.
A decent, competent installer will be able to the calcs and see what’s possible.
Radiator sizing is the other half of the equation. As flow temperatures drop, radiator output drops significantly, so they need to be sized correctly for low-temperature operation. If that’s done properly, you reduce the demand on the system and make everything easier to run efficiently.
A good installer should be measuring and calculating this, not guessing. That means checking heat loss room by room, confirming required emitter outputs at lower flow temperatures and then verifying the system can achieve the necessary flow rates through the existing pipework.
So the “right” approach is neither blindly ripping it out nor blindly keeping it… it’s assessing whether your current system can move the heat the heat pump will produce. If it can, keep it. If it can’t, then targeted upgrades are far better than a full repipe.
Posted by: @penvalInstalling ashp in early 2000 homes. We have a 2010 self build which we bought in 2013. Insulation is good but down stairs has a floating floor. We’re going to move from oil to ashp. We’re getting mixed messages about the existing system which is microbore pipes. Some advise ripping it out and re piping. It’s going to be messy. Others say that with modern ashp as long as the radiators are sized right it doesn’t matter. What is the right approach?
I am soon going to install and review an Adia Thermal connected to a Vaillant, microbore drops 10mm, no rad changes and no DHW change, they claim providing the rads are somewhere near correct size (they can be slightly under) they claim that this system works fine on microbore, manages and matches the ASHP, tariffs and pump speeds to minimise losses while TRV controlling every room. These are new to market but have a good length of testing so should be good.
I will be posting the installation, process and review on performance during May and onwards. It may be a solution for you?
@ashp-bobba bang on, and I can't reveal too much but there's another product that might be entering the market later this year that promises to commission and actively balance systems. These are all innovations that should hopefully start to make heat pumps work that little bit better.
@editor Nice, its about time, we need some professional add ons that help on that side of things to make these systems a bit more cost effective.
I can se I will get excited and be added an ASHP system to my shed to try that one out, I am running out of buildings to put test rigs in lol...
Oh I know I could offer trial sites at cost and try all this new stuff out 🙂
Hello @Penval
unfortunately, now the winter is gone and you missed that opportunity to mimic heat pump operation with your present oil burner to test the hydraulic system on usefulness. You can try anyway but results will less clear at mild outside temperatures.
Before you go on have pen and paper at hand to document any status quo before you start shifting levers (young people however will take pictures with their smart phones).
Procedure how to operate a heat pump is all over town already; turn the flow circulation pump to full blast and open any thermostatic radiator valves (TRVs) fully. Now control the system only from the weather compensation (WC) with a minimum possible flow temperature to keep rooms warm enough. Make notes of outdoor temperature, flow temperature and all return temperatures of the particular radiators. There might be rooms too cold by trend and some too warm .... keep records.
When there are lockshield valves ('RLVs')in the return pipes of the radiators, you might try manipulating them by throttling 'fast' or encouraging 'slow' emitters. Take double care then to remember their original setting. Have in mind that valves come with a 70/30-30/70 characteristic: at 30% opening the flow will be 70% already, the last 70% opening add 30% flow only. When thin tubing is involved, the flow is limited anyway and the whole action may be in the first quarter-turn of the valve. Mechanics use to think in 'spanner flats' (sixty degree angle) and 'half spanner flats' (thirty).
When you find out after a while that, let's say, flow temperature (FT) is around 40°C when it's outside 10°C, you may conclude that it will be 60°C at 0°C and find the latter to be scarce.
With cooler FTs it will be more promising, at even warmer flow temp. level you will want to get drastic.
Also return temperature will play a role; generally low levels indicate little flow; when little flow can increased e.g. by a stronger circulation pump, this means that for a constant heat supply FT can be lowered to please the heat-pump-to-come.
When overall results come out indistinct, you may consider to deliberately choose a too small heat pump .... boosting the living room with an oil filled radiator at some ten days per year may be more comfortable than laying waste to your lovely decoration.
When selecting a heat pump type, look at which temperatures which power is supplied -- two examples saying '10 kW' might be very different in detail. Also take care of the minimum flow requirement, e.g. 1000 l per hour will be 'ouch', 400 would be 'aaah'.
Last-generation R290 (propan) pumps are said to supply high flow tempeatures while not sacrificing too much efficiency, but when comparing figures, I find no big differences. Anyway figures and reality may be different matters ('the difference between theory and practice is bigger in practice than in theory'). However many propan pumps are limited in their minimum power generation to roughly 35% of nominal value, which seems to come from lubrication issues relating to the refrigerant. R32 pumps can get to lower compressor rpms in average, at least with less trouble or risks.
The rented 45-m²-two-bedroom-ground-floor-flat I'm sitting in at the moment, comes with a 30 kW Worcester compact gas boiler and, I think, nominal 6 kW of panel radiators installed with microbore piping. The Worcester manual says 'DHW minimum heat input 7.3 kW', and on full blast (85°C FT) and all TRVs fully open, the boiler heats without cycling, so I assume that it puts plusminus 7 kW into the system. When the wife moved in here, of all things the living room radiators came slow, which I could tweak easily by turning the lockshield valves.
When 7 kW heat transport take place at some 60°C temp. difference between room and radiators, it may be like 2000 W at 20°C, so fourtysomething centigrade FT.
The flat is made of cavity walls, already blown out, with nice new windows featuring low-E-glass, so I assume that the overall heat loss will be like 60 W/K and 2000 W cover nearly everything even when the tenant in the first floor will be absent with his heating turned off.
It is difficult to get climate data here (compare e.g. https://www.stiebel-eltron.de/toolbox/klimadaten/ and cry bitterly) but I found some official website saying that we can expect half an ice day per year -- I think, as long as there's outdoor plumbing downtown, there's not much of frost to expect.
So, bottom line, the said flat here would qualify for a heat pump easily, just as an example.
Now it's your turn, and later, tell us what came out!
Sooooo, what did we do in the end? We approached three installers and two responded. One quoted a minimal disrupt solution of which we were wary. Many thanks for the comments from everybody which helped inform our decision. We finally went for a proposal from Alter Eco Renwables based just down the road in Nantwich.
They provided a very detailed proposal. Heat loss calculations for every room matched to radiator outputs. They suggested 6 radiator swaps plus a kick board fan in the kitchen which is an odd shape and has a couple of designer radiators in which we didn't want to lose. We had a choice of 3 ASHPs from Grant, Samsung and Daiken. We went for the Samsung Mono R290 8kW with the added reassurance that Alter Eco are a Samsung agent. We were given estimated COP at a range of temperatures and power consumption figures based on load. We also had a new 300 litre water tank. There's no buffer tank.
Most of the pipework from the hot water feed was replaced with 25 mm copper. The 10 mm feed from the 25 mm to the radiators was left.The ASHP had to go where the oil tank had been so the side of the house had to be dug up and a large, insulated flow and return went into the ground.
Of course, we had this done during the hottest summer ever so apart from commissioning it hasn't yet had to do a lot. Every Tuesday at 3:00 am it heats to 60C as part of its legionella cycle. The Eddi (we have a myenergi solar/battery system with a diverter) keeps the hot water hot at 48/50 C. However, last weekend we had a colder morning, 9C outside, and everything started to work . It took about an hour for the house to regain its normal temperature of 21C. The system ran at 23 litres flow with a flow temperature of 35C. This all looks very promising for the colder months. Of course, nothing has had to switch on since but I'm quietly confident. To date, the ASHP has run on stored solar but it seemed to be using about 1kWh when it operated. I expect that to go up when it gets colder and, of course, we won't have the benefit of stored solar in the winter months but we do charge the batteries on the cheaper overnight tariff when the sun doesn't shine.
Finally, a shout out to Arron, John and Jamie at Alter Eco. Quality of service from design to commissioning was outstanding. The workmanship of a very high quality, once tested everything was insulated, joints were sealed and when they left site everything was clean and tidy and made good. They are available for questions and will return October/November to make any changes to the seasonal compensation curve. They arranged the BUS grant and have arranged a Building regs certificate for the work.
We understand now how anxious people can get when they make the change especially if it's older people, which we are. There's a lot of uncertainty both in the technology and in making the right choice of installer. People need to have confidence that the MCP certification process really does guarantee a standard of service because at the end of the day heat loss calculations, coefficient of performance, flow temperature and flow rates are all very well but an old fossil fuel boiler went up on the wall and it worked. People don't care about the technicalities but they do need reassurance in order to persuade them to take this giant step. Just sayin'
@penval, really useful update. After all the discussion earlier about whether the microbore would have to come out, it’s encouraging that you’ve ended up with a much more targeted approach rather than ripping everything apart.
The first colder weather signs sound positive too. Obviously the proper test will come when winter truly arrives, but I’d be interested to see how the system behaves once temperatures get down towards freezing and whether you end up needing much adjustment to the weather compensation.
Your final point probably resonates with me most. Most homeowners simply aren’t going to spend months learning about pipe sizes, flow rates, emitters and heat loss calculations before changing their heating system. They need to be able to trust the people designing and installing it.
From what you’ve described, Alter Eco seem to have approached yours thoughtfully, which is exactly what you want.
Definitely keep us posted through the winter. That will be the interesting bit now.
- 2,838 Topics
- 67.5 K Posts
- 1,145 Online
- 7,259 Members
