Swedish retrofit pr...
Swedish retrofit product that guarantees heat pump SCOPs of 10!
7 Users
12 Reactions
Your energy: 137 kWh
Topic starter   [#2919]
A new Swedish retrofit product has been announced guaranteeing a heat pump SCOP of 10 for just £199!
The system combines a heat-recovery TRV with an adaptive outdoor sensor using reverse weather compensation to dynamically reduce system demand and recycle internal heat gains.
Full breakdown here: https://youtu.be/L_JIcUglbmM
Your energy: 45 kWh
I looked at the publishing date before I watched the ‘presentation’😆 Thank you Mars - good on you! Toodles.
Your energy: 167 kWh
I want one and plan to add it to my Christmas list, along with the repeal of the second law of thermodynamics.
Your energy: 45 kWh
@jamespa Why not two or more - double your COP to TWENTY!!!!!🤩 Toodles.
MK4
 MK4
(@mk4)
I enthusiastically started watching the video, even though the 10 seemed way too good, then the size of the valve seemed miraculously small, the concept of reverse wc odd, but I kept going because I wanted it to be true. Well done Mars, you gave me a good laugh and made my day!
This post was modified 8 months ago by MK4
(@batpred)
Your energy: 31 kWh
I reads this is not available outside 01/04. Best to buy half a dozen, as it will fly off the shelves...
And don´t forget to get a few plug in PV kits as well. It seems Ed found a way to make them 60% efficient.. 😆
This post was modified 8 months ago by Batpred
Posted by: @batpred
I fear you may be right!
Im still up for supporting the repeal of the second law of thermodynamics.  Now there is a policy for (the many) crackpot politicians to whom the truth means very little.
This post was modified 8 months ago 2 times by JamesPa
bobflux
(@bobflux)
Your energy: 29 kWh
Posted by: @toodles
With enough PV and fudging definitions to mean COP = heat output / grid input it's doable
(@lejamaiscontent)
@jamespa
see https://en.wikipedia.org/wiki/Indiana_pi_bill
My proposal to improve that Swedish approach: at the electric power supply, swap L and N on warm days to make the heat pump reverse, thus cooling down rooms while converting heat gain into electric energy.
