Cooling with air to water heat pumps
A quick update.
I finally found a 'solar' roller blind with a silvered outside face. It actually wasn't any more effective than the white venetian blinds I already had so I'm not sticking with it.
I have had new double glazing all round. The clincher was that the window openings weren't accessible. To get good ventilation over night I was climbing over furniture in every room. I think it will reduce my solar gain. Not least because with wider frames the glass area is reduced quite a bit. Ventilation is also much better. There's been no heat wave since it went in but if we get another I'll let you know.
Posted by: @springswoodA quick update.
Passive cooling should always be the first call. Keep the heat out rather than trying to extract it by using more heat! Southern European countries have this embedded in their psyche and building design, the laws of physics are the same in the UK as in Spain so we shouldn't be re-inventing the wheel (or worse still, in true British exceptionalist fashion, inventing a square one of our own!)
- 2,820 Topics
- 66.9 K Posts
- 2,290 Online
- 7,234 Members
By the same measure we should be insisting that all gas...
By Batpred , 3 hours ago
True but .. because the room is colder dt rad to room i...
By JamesPa , 3 hours ago
Got two or three heat pump quotes that don’t agree? Post them here.
One of the biggest sources of confusion I see on Renewa...
By Mars , 3 hours ago
I do not disagree with the concept of wanting to live a...
@singlespeed I am going to put a temperature sensor on ...
By fosterl2 , 5 hours ago
RE: Grant Aerona - Weather Compensation and Schedules
@taffonthetaff Yes, I have now gotten to the bottom of ...
By bontwoody , 6 hours ago
Occasionally our Grant R290 activates all three circuit...
By TaffontheTaff , 6 hours ago
@davec 47kwh for 3 days is very low, compared to what I...
By johnd , 7 hours ago
By JamesPa , 12 hours ago
By Mars , 12 hours ago
Do heat pump defrost cycles impair heat pump efficiency (COP values)?
The short answer is no, as far as I can see from data f...
By cathodeRay , 12 hours ago
By Judith , 1 day ago
