Issues with Samsung...
Issues with Samsung heat pump – high running costs and house dropping to 11C overnight
4 Users
1 Reactions
(@jwilliams89)
@jamespa I doubt they are supposed to use it. They are supposed to run everything through the external stat (EPH) and ignore the cost.. I hate poorly fitted systems so much.
I'm pretty sure 2093 is set to 1, but I'll get them to check and report back. He did say he couldn't find a 3 way, only a valve with a return and feed, and two pipes going on, which presumably is the diverter. I'll get him to test them for heat.
I would say it only seems to be calling for heat from DHW, as water outlet temp is always around DHW temps not heating temps.
Posted by: @jwilliams89
Indeed to the last comment.
Can you get a picture and model number of the external controller?  They appear to do several variants which, unfortunately, look the same.
.. and of the valves and nearby pipework, ideally also the model numbers
Quite possibly, or alternatively the external controller is calling for heat but the heat pump has been told to ignore the call.  Either way if only DHW temps are produced then its a big clue!
Can you also ask for pictures of any tanks, so we can determine whether there is a buffer tank or not.
Sounds an awful lot like this was installed by a numpty who perhaps has a vague idea about fixed FT boilers but not a clue about anything (boiler or heat pump) featuring weather compensation.  My guess is that he has used that knowledge to plumb and fit the controls for this system ... badly
Hopefully its not too difficult to sort out once diagnosed, but it really shouldn't be necessary!  Diagnosing it remotely is not going to be easy so if there is someone local that would be preferable.
This post was modified 34 minutes ago 2 times by JamesPa
Page 2 / 2
