Octopussy cosy 6 ex...
Octopussy cosy 6 experience
8 Users
3 Reactions
(@mk1234)
New Member Member
@paultheheating fair enough on the oil, that's the tenant's business. For real long-term data rather than brochure figures, have a look at heatpumpmonitor.org. There are around ten Cosy 6 and Cosy 9 systems listed publicly (Colchester, Derbyshire, Leeds, Cheltenham, Birmingham and a few others), with measured heat out and electricity in, so you can see what they actually achieve in normal houses.
On the SCOP worry I'd go with Majordennisbloodnok: published figures are often quoted at different flow temperatures (35 vs 55 °C), so make sure you compare at the same one. In practice the install and the flow temp it ends up running at move the result more than the badge on the box.
(@watcher)
@toodles
👍 …..and either will beat oil!
Paul, if you don’t care how much oil they use why worry about a bit of difference in hypothetical scop numbers?
Incidentally the link in my first post shows the whole Octopus fleet and as the 12 was only launched latterly the bulk will be 6 or 9’s.
Am I the only Cosy owner on here??
(@paultheheating)
interested in scop numbers only to ensure that current tenants do not leave due to lack of warmth for their money.
and to show to epc chap that ashp gets higher score for moving from d rate to c rate.
thanks will look at heatpumpmonitor.org
@paultheheating Unless things have changed more recently than the last articles I have read, the EPC disregards the upgrade to a heat pump over gas as they seem to regard this as immaterial! (Can any reader tell me if this attitude has changed please?) Toodles.
(@paultheheating)
@toodles thanks but we would be moving from an old inefficient oil boiler to ashp so would expect epc should jump from d to c but agree things are not at all clear in just how many points the epc man will award for such an upgrade, the whole epc system is terrible. they quote rubbish like it could improve 3 to 15 points but no definite number.
also looked at heatpumpmonitor.org they only provide one result for an octo 6 and one for octo 9 but both appear to perform really poorly compared  to valiant arotherm
@paultheheating Even though I was able to show the assessor a drawing indicating the fabric and insulation of a subsequent extension to our home from the 70’s, this cut no ice with him and against the appropriate columns, he just typed N/A. I am of the opinion that much of the assessing was carried out with a wet finger in the air type of measurement. The cavity wall insulation was about to be dismissed until I showed him the ICI sustificate and the plate screwed to the wall stating the the walls had been filled. But then, what might one expect these days when someone has to turn up, spend about an hour measuring the building width, length, height of rooms, depth of reveals etc. Typing it all into a laptop programme and submitting it for registration and then receiving a fee of ~£60 for his troubles?! The assessor probably didn’t get more than 50% of the fee as the organising company would be taking their cut too. You pay peanuts ……. Toodles.
This post was modified 1 week ago by Toodles
Posted by: @paultheheating
People who have a Cosy appear generally to be happy with running costs if what we hear on this forum is anything to go by.
Vaillant arotherms appear, based on my own experience and that of others on this forum, pretty reliably to deliver a scop of about 4 with rads at say 45C unless they are oversized by a factor of 2 or more or have been saddled with a buffer.
Either way running costs should be quite a lot less than oil at present, but of course oil prices are very volatile so when oil is super cheap as it was a couple of years ago a heat pump may well cost more.
If you want a more accurate assessment of future relative costs than that you will need a crystal ball!
This post was modified 1 week ago by JamesPa
Page 2 / 2
