Octopussy cosy 6 experience
am thinking of octo cosy 6 for a rental property, anyone out there with experience? trying to be green but do not want to loose tenants to high lecy bills
I have had one for 6 months, 376kwh @ 0.30p = £100? Predominately hot water with heating in October. I am guessing that the winter 6 months will multiply that by 5 or 6, so still not overly expensive?
I am on Cosy tariff so about half that, you can set the cosy to bend use to the tariff so maybe 0.20p? So long as occupants avoid the 4-7pm higher prices for electric use or understand impact.
Nothing else electric will get close. They quoted 3.5 scop for the year and that looks achievable so far.
3 bed semi-bungalow.
This might help…
https://octopus.energy/cosy-heat-pump-performance/
I have a setup running on Cosy, 2 IVT ASHP serving 4 properties.
With 2x 20kwh Alpha battery towers to make the most of off-peak periods it works quite well.
Without the batteries the day and peak rates might be a bit dear.
thanks watcher, i need to keep it simple and to lowest budget, am sure that a solar aray and batteries would help lower the lecy cost for tenants but no roi for me as they pay for lecy.
👍 even on bog standard rate no other electric heating would touch a heat pump. solar & battery makes it a complete no brainer but not in your case. What other options are you considering?
currently property has an old more than 20 years oil boiler, so a new oil boiler could be an option, if I change to ashp then I will need to buy the tenants stock of heating oil, which is about 1000 pounds, we do not have gas
Posted by: @paultheheatingcurrently property has an old more than 20 years oil boiler, so a new oil boiler could be an option, if I change to ashp then I will need to buy the tenants stock of heating oil, which is about 1000 pounds, we do not have gas
At current oil prices I think you might be able to do a deal with the tenants whereby you dont buy the whole stock, given that ASHP is going to be a lot cheaper to run, or indeed sell the oil to someone else!
@paultheheating I'd look at it the same way as jamespa: at current oil prices the heat pump should be the cheaper option for the tenant, as long as it's sized and set up right. Two quick checks you can do from your own numbers:
Size. How many litres of oil does the property use a year? Litres x 10.35 kWh x ~0.8 (20+ year old boiler) gives the useful heat. Take off ~2,500 kWh for hot water and divide by about 2,200 hours. Example: 1,500 l works out at ~4.5 kW, so a Cosy 6 is fine. At 2,500 l you're nearer 8 kW and the Cosy 9 makes more sense. Worth knowing before the Octopus survey so you can challenge their figure.
Running cost for the tenant. Oil: price per litre / 8.3 = cost per kWh of heat (70p/l is about 8.4p). Heat pump: unit rate / SCOP. On Cosy at a blended ~20p and SCOP 3.5 that's about 5.7p. Even on a standard ~25p tariff it's about 7p.
What makes or breaks it in a rental is the tenant leaving it alone: weather compensation, steady setpoint, no big setbacks. A one-page note for the tenant does more for the bills than anything else.
If you want a room-by-room check on the radiators before the survey, tools like heatlosspro.cloud are handy for that.
Posted by: @jamespaPosted by: @paultheheatingcurrently property has an old more than 20 years oil boiler, so a new oil boiler could be an option, if I change to ashp then I will need to buy the tenants stock of heating oil, which is about 1000 pounds, we do not have gas
Assuming that if your property needs oil then the surrounding properties will be in a similar position, I wonder if any of the neighbours need an oil tank.
When we had our heat pump put in we obviously made our oil tank redundant. Moreover, we found that although the tank was in good nick and therefore had a value, there was also a not inconsiderable cost involved in getting it removed. As luck would have it, our next door neighbours had a tank that the oil company were getting concerned about (single skinned and degrading from sunlight), so we simply said to them that they could have ours if they paid for the removal and reinstallation. We only had a residual amount of oil but if we'd had a full tank then I'm sure we'd've been able to agree a reasonable price.
If its rented then also factor in the changing rules in EPCs and the new EPC scheme. Under the new EPC scheme although not entirely finalized (more delays than Trans Pennine Express) the intent is very much that gas or oil heating systems will not make a C in most circumstances, so after their first post 2030 EPC will not be rentable.
Thanks for the replies.
Am looking for any ones experience with octopussy 6 or 9 heat pumps installed more than a year
have no idea, and no interest in how much heating oil tenants use, that's their business
epc system is broken, and desperately needs replacing, in my case a new oil boiler could bring our rating to c as the cost of electricity is high and therefore does not give the expected score increase when looking at a octo 6
octopus has the advantage that they install their own machine, so more difficult for them to blame someone else if the install fails, but their machines seem to have lower scop performance compared to others.
@paultheheating Are they comparing like with like though? If one rates performance on the apple scale and the other on the pear scale….. Toodles.
- 2,827 Topics
- 67.1 K Posts
- 1,344 Online
- 7,246 Members
