We had expected The Treasury to claw back money allocated to DESNZ in order to meet the budget proposals from last month.
The BUS was a likely candidate to be curtailed.
However, I received this announcement today:
It's good news that this year's £400 million allocation for BUS vouchers has been supplemented by a £120 million "over-allocation". Certainly that is better than allowing the funding to run out around the end of the calendar year, and then having a waiting period until April - that would make no sense. However, as approx. £750 million has just been removed from the total BUS allocation in the budget, one can only assume that DESNZ will keep permitting "over-allocation" each year until there is none left. The political optics of that are better than the alternative which is to reduce the size of each grant. If subsequent years continue to consume circa £520 million, the funding will run out approx 1 year early in March 2029, just in time for a general election if we haven't had one before then.
@etchedpixels, my understanding is that there are two slightly different things going on here, and I think it's important not to confuse the permission to issue more vouchers with the government actually making more money available. What DESNZ has announced is that Ofgem can now issue up to £520 million worth of BUS vouchers against this year's £400 million budget, presumably to prevent applications grinding to a halt if demand continues to grow, but that doesn't mean the Treasury has suddenly found another £120 million to spend, and the announcement doesn't explain how those additional commitments will ultimately be funded.
What's interesting is that the Treasury has already done precisely what many suspected it might do in last week's Autumn Budget, because the government's Warm Homes Plan had originally allocated £600 million to BUS for 2027/28, and that's now been reduced to £400 million, with subsequent increases expected to broadly follow inflation rather than the considerably more ambitious funding commitments announced earlier this year. So we're effectively seeing the government allow more vouchers to be issued this year while simultaneously reducing next year's planned funding by a third, which seems a rather contradictory approach when demand is apparently heading in the right direction. It's all a bit odd.
I wouldn't be surprised if this sort of thing doesn't go on all the time and I wouldn't necessarily assume the money will come out of next year's bus grant pot. Budgets are estimates and one expects to overspend some and underspend others. Sometimes, as in this case maybe, an overspend is welcome!
Certainly in the local government world it's normal and even has a verb attached to it namely to vire. I can't see why central government would be any different.
That does not mean that next year isn't reduced, just that it might not be reduced by this year's overspend.
It may now be normal to overspend, but I remember when the green homes grant (or whatever insulation grant) was cut short in terms of the window during which the funding was available. They actually cut it so short that some of the work that had been committed could not go ahead (probably worse with sales made by pop-up offices that could not tell EWI from any other kind). Anyway, that caught us and so we were left with a useless voucher in our hands..
Posted by: @rob-of-yorkIt's good news that this year's £400 million allocation for BUS vouchers has been supplemented by a £120 million "over-allocation".
I doubt they will hit the existing budget limit, looking at the BUS statistics from April 2026 to end Sept 2026 they issued 26,691 vouchers, of which only 17,484 voucher redemption applications were received, with 16,633 vouchers actually going all the way to payment.
So assuming worst case that every application was the max £9000 grant, the first 6 months was 16,633 payments x £9k = ~£150M.
That leaves £250M of the original budget, or 27,777 x £9k vouchers, equates to 4,629 payments per month for the remaining 6 months of the financial year. Now even the last month of Sept 26 with demand at it's highest, only saw 3,332 payments.
I wouldn't be surprised if they fail to spend all of the existing budget.
Posted by: @batpredIt may now be normal to overspend, but I remember when the green homes grant (or whatever insulation grant) was cut short in terms of the window during which the funding was available. They actually cut it so short that some of the work that had been committed could not go ahead (probably worse with sales made by pop-up offices that could not tell EWI from any other kind). Anyway, that caught us and so we were left with a useless voucher in our hands..
That's disturbing, I hope you didn't lose out.
I wasn't suggesting it's normal to overspend only that moving money between budget lines is quite usual, at least in the local government world. Budgets are probably prepared 6 months or more before the start of a budget year, so that's 18 months before the end of a budget year. A lot can and does change in that time, they will never be spot on at the individual line level.
There is a good summary of the position before the extra "over-allocation" here:
https://www.eliterenewables.co.uk/blog/boiler-upgrade-scheme-budget-cut/
The £143 million remaining for the rest of 2026/27 is an OFGEM figure, see https://www.ofgem.gov.uk/data/bus-monthly-scheme-update Note the footnote about this being a dynamic value.
I think DESNZ and OFGEM count in a different way, which is somewhat confusing. Anyway, I think there must be a concern that the funding could run out this financial year, otherwise there would be no need to permit an over-allocation.
Posted by: @rob-of-yorkI think DESNZ and OFGEM count in a different way, which is somewhat confusing. Anyway, I think there must be a concern that the funding could run out this financial year, otherwise there would be no need to permit an over-allocation.
The official statistics state 16,633 vouchers paid April 2026 - Sept 2026, so ~£150M paid out assuming worst-case £9k grant, so in reality with a mix of grant amounts, less than £150M paid out.
Official government statistics have to comply with greater standards of accuracy than the usual Government departmental PR and puff statements, so for accuracy I'd go with the official statistics.
Possibly their budgeting process is more cautious and based on vouchers issued, on the assumption they could all be redeemed, but in reality they never are all redeemed and the stats show a lot of applicants dropping out before they get the payment stage.
https://www.gov.uk/government/collections/boiler-upgrade-scheme-statistics
I don't doubt the veracity of the Govt statistics. However, it is not only the number of BUS grant vouchers paid (16,633 for Apr to Sept 2026) some of which will have been issued in the previous financial year, but also the number issued (26,691 for Apr to Sept 2026) that matters, since each issued voucher is also a liability for OFGEM to pay once the work is completed (less those that expire).
OFGEM publish quarterly reports (latest one to end Aug 2026 here:
) and also monthly updates (latest one to end Sept here: https://www.ofgem.gov.uk/data/bus-monthly-scheme-update ).
From the vouchers issued, paid, expired, and undetermined (i.e. currently in the queue to be looked at) OFGEM works out the remaining budget for the financial year. This determines whether or not there is any money left for further vouchers to be issued to any subsequent applications entering the system. To quote OFGEM, "Remaining budget includes all undetermined applications and vouchers issued yet to be redeemed, this is a dynamic value, as vouchers expire or return then more budget becomes available for future vouchers to be issued." In this way OFGEM tracts the point at which it would necessarily have to stop taking any more applications if all of those in the queue to be looked at and all those issued turned into paid ones within the current financial year.
At the end of Sept 2026, the remaining budget according to OFGEM was £143,585,000 and that value had dropped by £90,232,000 in two months since the end of July. At that rate, the remaining budget could have hit zero around the end of the calendar year causing OFGEM to effectively halt BUS grant applications. That would be a bad outcome and so a £120,000,000 over-allocation has now been permitted.
Posted by: @temperature_gradientOfficial government statistics have to comply with greater standards of accuracy than the usual Government departmental PR and puff statements, so for accuracy I'd go with the official statistics.
Posted by: @rob-of-yorkI don't doubt the veracity of the Govt statistics.
But I do! We should always doubt the veracity of 'official' government statistics. It and its various departments and agencies all have agendas to push as much as anyone else. Here are the facts, now where is the evidence, and all that.
As it happens yesterday I went through the various stats under discussion and found wide discrepancies such that the only possible sensible conclusion is that some or all of them are wrong. Here is a summary.
There are three main published sources of data. As is so often the case they use different geographies (UK vs England and Wales etc) and different intervals (monthly, quarterly, calendar vs financial year), different definitions of 'cases' (all heat pumps vs breakdown by type of heat pump) and all are subject to various forms of reporting delay. However, with some jiggery pokery it is possible to compare like with like. The sources in no particular order are:
(a) the Boiler Upgrade Scheme (BUS) statistics, which count the number of BUS grant applications received processed and paid. These cover only England and Wales, but are usually the most up to date. By definition these are grant assisted retrofit installations, and so should be MCS certified, but will exclude DIY installations, new builds etc. The intervals are monthly, and the numbers are broken down by type of heat pump. There is an assumption that a voucher paid equals an installation completed.
(b) the Heat pump deployment (HPD) statistics, which are based on MCS data (certifications), and cover the whole of the UK. The source and processing of earlier data is somewhat opaque (see the 'What you need to know about these statistics' and 'Methodology' sections on this page), and the publisher (DESNZ) describes them as 'Official Statistics in development', whatever that means in practice. The intervals are calendar years divided into quarters. The regional breakdown is not divided by type of heat pump.
(c) the Ofgem's BUS numbers, which mostly report the amounts paid out in GBP for BUS grants (so E&W, retrofits ie the same base as the BUS statistics above), from which it should be possible to estimate the number of grants. Ofgem claims they are monthly reports, but in fact they are annual financial year numbers, and publication appears to be somewhat erratic (see the wayback machine: on the 13 Feb 2026 the remaining (unspent) budget for Year 4 (2025/26) was £50,662,500, implying £350 million already paid out, but the latest 'update' (13th Oct 2026) says the total spend for Year 4 (2025/26) was £232,255,000, suggesting that somewhere along the way rather of lot of vouchers got lost down the back of the sofa.
The minor variations in the way the data is presented are tiresome, but with a bit of effort it is possible to determine for each source the total number of heat pumps (air and ground source to water) for the financial year 2025/26. For the BUS and HPD statistics, it is a simple sum of the relevant cells in the spreadsheet. The Ofgem numbers need to be reverse engineered, which I have done by assuming each grant paid was for £7,750 (up from £7,500 to account for the small number of £9,000 grants). Ofgem's numbers are not broken down by type of heat source, but the numbers of non-air/ground to water sources are so small that they can be ignored for our current purposes.
The results (E&W, 2025/26 financial year):
BUS statistics: 30,898 installations
HPD statistics: 44,780 installations
Ofgem BUS update: I give up. It is impossible to know how much they paid out. It may be somewhere between £250m and £350m. Lets say it was £300m, then at £7,750 per voucher, that is 38,709 installations.
Now ultimately all these numbers should be very closely related - BUS grants need MCS certification, MCS certification is almost always done to get a BUS grant. Yet the estimates vary hugely. Don't get started on things like reporting delays, the discrepancies are far to large. At least one source, if not all sources, of these 'official statistics' are just plain wrong.
- 2,830 Topics
- 67.3 K Posts
- 2,202 Online
- 7,253 Members
