Ecodan with FTC7 - True Weather Compensation
Posted by: @danwright90I hold off for now with the hardware but i may still get the MELCloud receiver as this would give me flow temperatures as right now, i am in the blind.
Some data is definitely useful. I ordered the internet connection for my Vaillant heat pump and use Home assistant to pick up some basic data because, unlike Mitsubishi, there is no graphical online portal and the app doesn't present much graphically. It has got me out of a couple of holes and proved useful in helping others also!
I would definitely suggest a solution to give you system data is useful, if not essential for identifying issues. I'm not sure what the MELCloud receiver costs to purchase, but the MELCloud app itself is very limited in what it provides. There is potentially one specific alternative option available, which is a dongle device produced by one of the forum users, @f1p, which sells for around £35 and which plugs into the same connection, the CN105 port, that the MelCloud adapter would use.
The information you can get from this, either via Home Assistant, or the MelPump app, is far better for the end user, so it is potentially an inexpensive alternative. For info, the graph data I included in my original reply was from the MelPump app. I was initially sceptical about being able to install it, but had help from @f1p and @majordennisbloodnok via this forum. From your current point of lacking the wifi adapter for MelCloud, I suspect that this might prove to be a better option at lower cost. (NB: just checked and it looks like the Mitsubishi option is around £100-£120 to purchase, so I definitely think this would be the case).
Separately, I think there is a way for you to see real-time flow temperatures within the FTC7 controller, possibly within the installer settings, from memory. I'll see if I can include how to do this in a video clip too. You'll only get a real-time snapshot of the sensors at that point in time, but it sounds like that's better than nothing currently.
Posted by: @danwright90The installers are registered, highly recommended, so i do trust the install.
As you appear not to be too comfortable with how it has been set up, do the installers have anything to contribute?
With the multiplicity of additional controls, I am not sure how the weather compensation performance can be evaluated. It sounds a bit like how I started with all radiators having Tado SRV's
2 x Growatt 7.5kW Batteries
Fronius EV Charger
Kia e- Niro 64kW
I've linked two videos below recorded this evening, one for getting flow temp info and another for you to check that your weather compensation settings are all set correctly (i.e. where the various functions are, rather than copy exactly what mine are doing). Hopefully they're of use as an initial sense check. I've uploaded them via Vimeo, as they're too large to post directly on the forum.
5 days ago
Ecodan Zone 2 Mitshibishi thermostat Auto Adapt
1 month ago
Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
2 months ago
New Mitsubishi Ecodan 11.2kW installation - L9 errors and maybe more
2 months ago
2 months ago
- 462 Online
By Renewables345 , 29 minutes ago
By MartinHook_UK , 40 minutes ago
By benson , 49 minutes ago
By cathodeRay , 2 hours ago
By bobflux , 2 hours ago
By bobflux , 3 hours ago
By Jonatan , 8 hours ago
By bobflux , 14 hours ago
By Batpred , 15 hours ago
By Transparent , 18 hours ago
By bobflux , 19 hours ago
By Toodles , 21 hours ago
