Knock on effective of balancing radiators
Posted by: @bashWhat is the rough amount of flow that I'll get from the first quarter turn, would it be around half?
It's very dependent on the lsv, heat geek did a series of experiments (search for 'valve authority') and found the control range varied from 0.25 turns to 2 turns depending on model.
Posted by: @bashI was starting to come to the conclusion that that FRVs whilst useful, could end up being the best part of £1000 to fit and I don't really want to pay that
We’ve covered some of this over DM, but for everyone else following along, there’s potentially a “smart” alternative to FRVs due to hit the market later this year. Different manufacturer, different approach. I’ve signed an NDA so can’t share specifics, but the key point is that it dynamically balances the system in response to real heating demand rather than relying on static pre-set flow limits.
On conventional FRVs, our experience has been mixed. In principle, they’re a tidy solution. Do the room-by-room heat loss, calculate the required litres per minute, set the valve accordingly and they should hold that flow rate regardless of pressure fluctuations elsewhere in the system. In practice, they did a reasonable job for us at “normal” flows.
Where it became problematic was at very low flow rates. When we tried throttling certain radiators down to around or under 0.5 L/min, the valve didn’t appear to modulate… instead it effectively shut the radiator off. We saw this repeatedly at settings below roughly 1 L/min across five rads. The radiator would go stone cold, forcing us to increase the setting to over 1 L/min, which was more than that emitter actually required from a design perspective.
So while FRVs can be useful, particularly in systems with pressure variability, I don’t think they’re a silver bullet.
I find it quite ironic that most of this heating/plumbing business is about controlling flow and pressure, without actually measuring flow and pressure! Strange rules for a game, when you think about it...
Now a ultrasonic heat meter costs 20€ in medium quantity on alibaba... Motorized ball valve costs 10€... Pressure sensors are also quite cheap... The call of over engineering is too hard to resist 🤣
Posted by: @bobfluxI find it quite ironic that most of this heating/plumbing business is about controlling flow and pressure, without actually measuring flow and pressure! Strange rules for a game, when you think about it...
Thats a very astute observation. Its like an electrician working without any test equipment!
I'm looking for a cap to replace the TRV. Whilst all of mine downstairs are fully open, I'm given to understand that there is still pressure on the valve that constricts the flow. I want to remove the TRV but not leave the valve exposed. All I see are decorator caps that achieve the opposite by completely closing the valve. Ideas please.
Posted by: @morganI'm looking for a cap to replace the TRV. Whilst all of mine downstairs are fully open, I'm given to understand that there is still pressure on the valve that constricts the flow. I want to remove the TRV but not leave the valve exposed. All I see are decorator caps that achieve the opposite by completely closing the valve. Ideas please.
Decorators caps, not screwed down (they can actually be used to adjust the flow) or the original head just balanced on top. I do the second of these but if you have children or dogs they will get knocked off so perhaps in this case the first is better.
- 2,505 Topics
- 58.1 K Posts
- 256 Online
- 6,237 Members
I had avoided answering the poll for this reason, as th...
By Sheriff Fatman , 3 minutes ago
RE: Knock on effective of balancing radiators
Decorators caps, not screwed down (they can actually be...
By JamesPa , 30 minutes ago
RE: New Solar, Batteries, Air Source and Under Floor Heating advice please
@jamespa Thanks James, historically the rooms on the...
By sjc123456789 , 1 hour ago
@craigh Hello, I had best explain how my Homely control...
By Toodles , 1 hour ago
@travellingwave Just to add to what @mars has said, j...
By JamesPa , 1 hour ago
@cathoderay - thanks for an interesting discussion! T...
By RobS , 13 hours ago
The road to upgrading to the latest CU standard is ofte...
By Batpred , 13 hours ago
@benson thanks a lot.
By Tasos , 14 hours ago
I'm not so sure that the rest of society values a maths...
By JamesPa , 15 hours ago
Thanks a lot GC61 - I'll open a separate thread in due ...
By Kev1964-IRL , 17 hours ago
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
@falesh having a house of similar age the two issues I ...
By Terry1812 , 18 hours ago
RE: Our Experience installing a heat pump into a Grade 2 Listed stone house
Remember that the house continues to lose energy when t...
By JamesPa , 18 hours ago
@editor I'd missed that, and it's a very good response ...
By Sheriff Fatman , 21 hours ago
There has been quite a bit of discussion (mostly on OEM...
By MartinRobinson , 22 hours ago
@af1 My EPC rating jumped from E to C after installatio...
By dr_dongle , 1 day ago
@odd_lion the minimum MCS requirement is 2.8. I don't...
By benson , 1 day ago
RE: Advice on potential HW Cylinder size
I think the comment about heating from cold is quicker ...
By sjcsystems , 1 day ago
RE: Ideal HP290 14kW ASHP - how to optimise
Hi You can get a stethoscope for less than 10€ on Ama...
By bobflux , 1 day ago
Your DT is to low, you do not have enough heat exchange...
By ASHP-BOBBA , 2 days ago
I am aware. But is your chart direct from a Pace BMS ap...
RE: Call for heat on open loop weather comp system
I don't know Grant system but most ASHP are very simila...
@painter26 — good idea. Please do let us know what he s...
Yes, but I need to reopen the battery box.. I just noti...
