ASHP Energy Consumption/ Useage
Could someone point me in the direction of a reasonably simple way in which energy consumption and usage might be collected? I am interested in overall efficiency, but also information which will assist in integration of solar into the equation.
At my age, I cannot justify a large investment in hardware to achieve this.
2 x Growatt 7.5kW Batteries
Fronius EV Charger
Kia e- Niro 64kW
A simple electric meter (have works fine)
Or if you need smarter (not used just the first I came across)
Posted by: @davidalgarveI am interested in overall efficiency, but also information which will assist in integration of solar into the equation
Do you really need to do anything. I tried to do clever things then realised, the heat pump is most efficient ticking over all the time, it naturally makes use of all PV it can use, so deleted all the smart stuff and leave the ASHP to get on with it.
Thanks Johnmo.
Firstly, I should have made it clear that I am on a 3 phase supply in Portugal and it doesn't look as though I am going to get anything for energy exported to EDP.
I have tuned the heat pump to a reasonable standard on Weather Compensation, although I still have one more change to make and will see how this winter goes.
My main interest now is in integrating the newly installed solar PV.
I have some Smart Home so I am looking at a Tuya Smart 3 Phase ZigBee Energy Meter:
Comments?
Fronius EV Charger
Kia e- Niro 64kW
Posted by: @davidalgarvedoesn't look as though I am going to get anything for energy exported to EDP
I don't either, just use a PV diverter to an immersion charge the cylinder to 70 degrees, could just as easily be a panel heater in the winter.
I did try to put an Amazon link in for the ZigBee device but it didn't work so have tried again below.
On advice from others, I have decided that using the heat pump for DHW around midday, is more economical that buying and using a PV diverter/ immersion heater and this is just one of the areas that I would like to measure energy usage.
https://www.amazon.es/dp/B0BX5624GH/
Fronius EV Charger
Kia e- Niro 64kW
Still will not allow the link!
Fronius EV Charger
Kia e- Niro 64kW
@davidalgarve I am unsure if this is the problem I sometime experience but having writted my prose, I try to attach a link (URL) that I have ‘copied’ but this hub doesn’t see anything to place in the text.
I have taken to putting the link into a page in Apple’s ‘Notes’ and then selecting that link and requesting ‘copy link’. I am then able to paste that link into my prose like this:
https://renewableheatinghub.co.uk/how-to-balance-radiators-the-role-of-the-lockshield-valve
And that seems to work for me.
Regards, Toodles.
Thanks Toodles. Will try to remember.
On the substance of my original question, i.e. best device to record power used for ASHP, I have looked at reviews of many 3 phase devices and in the absence of any suggestions, I have finally ordered a Shelly 3EM so will see how I go with this.
This is a WiFi device and I would have preferred a Zigbee, but it was on a special offer.
Fronius EV Charger
Kia e- Niro 64kW
@johnmo
Yes, so I understand. However, I took a different route on “SmartHome” and use a Hubitat hub. I won’t be doing anything sophisticated with the Shelly, just getting, hopefully, an accurate consumption figure to compare with the Ecodan ASHP figures and thus help in optimising integration with newly installed solar.
I was surprised that no one came up with any alternatives.
Fronius EV Charger
Kia e- Niro 64kW
- 2,613 Topics
- 61 K Posts
- 605 Online
- 6,979 Members
@batpred by default the socket (Indevolt call it the by...
By Mars , 7 hours ago
@toodles That’s way better per kWp performance than our...
By Papahuhu , 9 hours ago
I was showing a friend around all our renewable tech to...
By ChandyKris , 9 hours ago
Just seen the videos for the new arotherm pro. They’ve ...
By AdamK , 9 hours ago
The installer guide here suggests that the ODU has no ...
By JamesPa , 11 hours ago
RE: Anyone concerned about GivEnergy?
From the thisistsaffordshire web page it is indeed impo...
By KevH , 14 hours ago
We don't have time-stamps on those screenshots, nor do ...
By Transparent , 16 hours ago
It seems odd these companies don't design and ...
By ASHP-BOBBA , 1 day ago
RE: Ecoflow UK Support & Info Thread
As promised, the review is out:/p> See discount codes...
@cathoderay great, thank you.
By Painter26 , 2 days ago
RE: Microbore heat pump installs
When I wrote the piece I didn't have anything in mind, ...
RE: Water law settings... A year on
@jamespa I've adjusted a few parameters 201 is no...
By Profzarkov , 2 days ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
@lejamaiscontent There’s a couple of things to add. We ...
By Judith , 2 days ago
RE: Seeking ideas / information / commiseration - Pure Drive
That may well be correct. However we don't have enoug...
@editor Thank you. I joined because I really liked your...
By claireisamazing , 3 days ago
RE: UK DIY Battery: SEPLOS 48V 200Ah x2 + Sunsynk 8K – Safe Installation for Garage Conversion
@madsid I don't quite understand what extra you need...
By Bash , 3 days ago
@transparent thank you. Be Thursday before my mate giv...
By David999 , 3 days ago
@johnd our Peak system is no more. The installer cam...
By DaveC , 4 days ago
Hah! Well I guess we're all in the realm of conjectu...
Ah, not so useful then For sure, hopefully before ...
Thanks @editor I appreciate that things go wrong, bu...
By venkman , 4 days ago
AC coupled Pure Drive 10kW battery Solar PV Solis P...
By Little Lights , 4 days ago
Forum Handle: ispookie666 Manufacturer: Vaillant Mo...
By ispookie666 , 4 days ago
RE: A2A vs A2W: Which Heat Pump Would You Pick?
I'm fairly new to the forum and have not voted. Back...
