When registering, please note that you will not be able to change your username. It is also very important that you read and understand the Forum Rules & Terms of Use before signing up.
Renewable Heating Hub Forums
Well & Truly Off The Grid
Buy & Sell
- 25 Forums
- 1,441 Topics
- 30.2 K Posts
- 34 Online
- 1,225 Members
This is all a bit too frequentist for my liking. The pr...
By scrchngwsl , 32 mins ago
ASHP Commissioning: What Questions Should I Ask the Installer?
All being well my Vaillant 12kw Arotherm Plus will be g...
By Declan90 , 53 mins ago
@ivanopinion I stumbled across this thread Performance ...
By GunboatDiplomat , 2 hours ago
RE: EV charger installation question – I don't want to bury the cable
Hmmm... That raises a lot of questions in my mind! ...
By Transparent , 7 hours ago
Relax with 4K drone footage of lawn mowing to a smooth Motown tune
Sending out some chilled weekend vibes to everyone. Lis...
By Mars , 10 hours ago
RE: Incorrect Billing of Customers with a Smart Meter
The starting point of that discussion on Camelot-Forum ...
By Transparent , 12 hours ago
Share Your Experiences with Heat Pump Manufacturer Support
Have you ever reached out to your air source heat pump ...
RE: Is this a bad installation and is there something wrong with my Samsung heat pump?
@ant87 thanks for that.
By David999 , 1 day ago
I might change my mind again, but I'm currently unlikel...
By IvanOpinion , 2 days ago
RE: Samsung ASHP scheduling help
@elgreco69 worth reading the GitHub here as that will a...
By morh , 2 days ago
RE: ASHP sizing - value of Heat Transfer Coefficient
@toodles Thanks for the explanation I get it now as I h...
By Jancold , 2 days ago
RE: Questions about yearly heat pump maintenance
For the installer, I believe servicing and maintenance ...
@retrorich It is very worrying that any of this should ...
RE: Spacing for roof fixing bolts ?
There is another consideration...but alas this doesn't ...
RE: Air source heat pumps and noise
Yes, but when they go wrong things get really sticky. D...
RE: Noise problems with newly installed Samsung 8kW ASHP
Hi, Bit of an update. I bought a decibel meter and moni...
By Lokisam , 2 days ago
RE: Are You Getting the Most Out of Your Renewable Energy?
As I mentioned, there are going to be some follow-up ar...
Now, I know that this may be a little simplistic and pe...
RE: Save the Energy Save the World using Daikin Altherma 3 operation mode and schedules settings.
Hello Mevl, I won't be able to answer all your question...
By HCas , 3 days ago
Heat Pump Humour
Latest Topics
By heat-pump-newbie 5 days ago
By jamesw 5 days ago
By KoRWraith 1 week ago
Home energy storage & battery register
By Mars 1 week ago
