When registering, please note that you will not be able to change your username.
When choosing a username, please avoid names that could be confused with a commercial brand unless you officially represent that brand. For example, usernames like Vaillant, Ecodan, Homely or Hive will be rejected if you have no affiliation with the company, as they create ambiguity for other users.
However, you can combine a brand name with your own name (e.g., Ecodan-John or Vaillant-Pete) as long as you include a clear disclaimer in your signature (the text added to the bottom of your posts). For example: “I am not affiliated with [Brand Name].”
This helps maintain transparency and ensures a positive experience for everyone in the community. Thank you for your understanding!
It is also very important that you read and understand the Forum Rules & Terms of Use before signing up.
Renewable Heating Hub Forums
Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Valves, Radiators & Controls (2 viewing)
Well & Truly Off The Grid
Buy & Sell
- 21 Forums
- 1,962 Topics
- 42.6 K Posts
- 56 Online
- 2,277 Members
Heat Pump Dramas?
Thinking about installing a heat pump but unsure where to start? Already have one but it’s not performing as expected? Or are you locked in a frustrating dispute with an installer or manufacturer? We’re here to help.
✅ Pre-Installation Planning
✅ Post-Installation Troubleshooting
✅ Performance Optimisation
✅ Complaint Support (Manufacturer & Installer)
RE: SolarPV tables / online calculator
We've only had our solar since last June, but so far fo...
By Old_Scientist , 3 minutes ago
@jamespa thanks, it's way off of the MCS performance es...
By big_si , 26 minutes ago
RE: Volumisers in Heat Pump Systems: Does Placement Matter?
@jamespa Agreed. I think it’s a case of much over muchn...
By Mars , 3 hours ago
@eliuccio Unfortunately, whilst I agree with a lot of...
By JamesPa , 3 hours ago
RE: Newbie out of her depth – Samsung AE120RXYDEG 12kW heat pump
@bami I think if the heat loss documentation matches a ...
By bontwoody , 3 hours ago
RE: What is the best strategy for operating a very oversized heat pump?
@jamespa I'm afraid that's over my head but if anyon...
By IRMartini , 4 hours ago
And here in case any one wants it is the code I used in...
By cathodeRay , 4 hours ago
RE: Samsung Gen 7 R290 12kW is not behaving how I expected
Definitely its in the 20xx FSVs. Conversely it may be...
By JamesPa , 4 hours ago
RE: Towel rails. An unexpected final hurdle
We have both Normal Rad for heating the room and then a...
By IRMartini , 6 hours ago
RE: Heat Pump Sizing & Installation Costs
Perhaps useful to have installed date too? To get conte...
By Tim441 , 8 hours ago
RE: F.788 Building circuit pump reports internal fault - Vaillant Arotherm
Guess I have to wait for engineer visit. I really hope ...
By jeegnesh , 22 hours ago
RE: Act now to defer the UK road tax increase on EVs
@majordennisbloodnok Damn right sir. my attempt at iron...
By Jancold , 1 day ago
RE: ASHP and heating issues in new build house
That’s good gives you more capacity. It made me think, ...
By Terry1812 , 1 day ago
RE: Seewet manhole cover within r290 exclusion zone
Thanks! I asked Vaillant, and they say I should be fi...
By dbrb2 , 1 day ago
Looking for the Grant Aerona 3 setting to turn off completely at 20 OAT
I'm running my Aerona 3 on WC and the 'warm end of that...
By damonc , 1 day ago
RE: Do I just go with the lowest quote for my heat pump?
So after signing in Sept in two weeks the install may s...
When you are renovating is always a good time, as it ma...
RE: Just one room not reaching desired temperature
Looks like this issue is now resolved. Aira installed a...
By ChandyKris , 1 day ago
Good point @jamespa But that probably strengthens @ch...
Latest Topics
By Mars 10 hours ago
By Mars 11 hours ago
By MichelleC 18 hours ago
By Toodles 2 days ago
