I looked at the trend in the link for booster - I see the booster on flag set but don’t see any corresponding rise in flow temp gets- makes me think you may not physically have a booster but the option might be enabled on the FTC. Or like me with my immersion heater - you have one but the power to it is switched off. I have noticed with the immersion heater that if the Ecodan decides to switch it on - and does not see any rise in temp it kind of gets into a death loop and just sits there with the immersion symbol (lightning bolt) on the screen but does not then attempt to to restart the heatpump - so you wake up to a cold shower. Could be the booster heater has a similar logic??
Could do to know what control mode you are using - weather comp or Auto adapt - from your trend looks like you are using weather comp but I’m not too familiar with MelPump App.
Ecodan Zone 2 Mitshibishi thermostat Auto Adapt
3 weeks ago
Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
1 month ago
1 month ago
New Mitsubishi Ecodan 11.2kW installation - L9 errors and maybe more
1 month ago
Ecodan with FTC7 - True Weather Compensation
2 months ago
Currently viewing this topic 3 users ( ASHP-BOBBA, Sheriff Fatman, Tasos ) and 4 guests.
Recently viewed by users: Travellingwave 31 minutes ago.
- 298 Online
I am aware. I managed to set the parameter on my JK bal...
By Batpred , 9 seconds ago
RE: Call for heat on open loop weather comp system
I don't know Grant system but most ASHP are very simula...
By ASHP-BOBBA , 4 minutes ago
And a picture of cylinder and surrounding pipe work wou...
By Travellingwave , 31 minutes ago
When TrustPilot accepted an appeal from a product manuf...
By Batpred , 44 minutes ago
Please excuse my persistence, but I am struggling to un...
By Tasos , 46 minutes ago
@painter26 — good idea. Please do let us know what he s...
By cathodeRay , 1 hour ago
@robs — thank you for your as ever valuable comments. T...
By cathodeRay , 2 hours ago
RE: Our Experience installing a heat pump into a Grade 2 Listed stone house
I beg to differ. I really could not make any useful pre...
By cathodeRay , 3 hours ago
@toodles It was the colour that threw me, yours was yel...
By Papahuhu , 3 hours ago
Yes, below are the projected figures from just three ye...
By Batpred , 3 hours ago
Yes, but I need to reopen the battery box.. I just noti...
By Batpred , 6 hours ago
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
If your heat loss is only 4kW and the pipes leaving the...
By JamesPa , 10 hours ago
My 2 bed mid-terrace definitely dropped consistently af...
By RadWhisperer , 13 hours ago
You can send private messages via the Messages (envelop...
By cathodeRay , 1 day ago
With complete radio silence from Peak and no sign of th...
By DaveC , 1 day ago
I understand now what you were referring to. This look...
By trebor12345 , 1 day ago
No you arent, because you dont need any, and furthermor...
As I mentioned earlier most radiators have a power outp...
By Batpred , 3 days ago
By DavidB , 3 days ago
By Slartibartfast , 3 days ago
