Replacing my 18 mon...
9 Users
15 Reactions
Posted by: @trebor12345
Regarding the last 3 cycles.  These are coming out of the defrost cycles, so the temperature rises.
Yes but it reaches a higher temperature than the previous defrost cycles, for which there must be an explanation.  This might give a clue to why the rest of the defrost cycles don't get back to 31.  We saw this behaviour before and its a bit puzzling.  Lets see what this night tells us.  I feel we need to get to the bottom of this.  I will keep thinking about it in the mean time.
Do you by any chance know what the heat pump thinks the TWO and TWI are at the high point of a defrost cycle and at a high point of a non defrost part.  It could just possibly be a buffer effect.  I cant immediately see a mechanism for the specific symptom but it would be good to rule this out, and the heat pump knows!
This post was modified 3 months ago by JamesPa
trebor12345
(@trebor12345)
I have been writing down the temperatures on the probes on top of the buffer.
High Point just prior to Defrost Cycle
Two - 28.8C (significant drop in temperature)
Twi - 26.3C
Water is a lot cooler because the HP is iced up and not producing the heat required.
High Point Normal Cycle
Two - 31.3C
Twi - 27.3C
Typically I see 31C into the top of the buffer.  4 or 5C across the floor manifold.  +0.7C differential across the lower ports of the buffer (so the mixing inside the buffer thats going on).
Hitachi Yutaki SCombi Heat Pump
(Indoor Unit ) RWD-3.0RW1E-220S-K
(Outdoor Unit) RAS-3WHVRP1
2024 build bungalow
Southern england
179 m2
High level of insulation
Underfloor heating
All 12 circuits are fully open all the time
1 thermostat in family room
7KW heat pump
50 litre buffer tank (4 port)
3.6KW solar panels
Energy used by heating 2527 KWh - 7527 KWh (SCOP 3.5 approx)
Thats an assumption you are making and it may well turn out to be true, but the evidence is entirely consistent with that:
In the first plot you shared the flow temperature drop occurred well before the onset of defrost cycling.  In both that plot and the latest plot the flow temperature rise also occurs about 3 cycles before defrost cycling ceases.  Now it may be both of these are due to OAT changes but we need to know for certain because...
If the heat pump cant keep up during defrost then your original statement that it is oversized cant be true, by definition, an thus getting a smaller one will make matters worse.  The exception to this would be if the heatpump is faulty
It also begs the question, if your house loss is 2.8kW, where is the rest going?
Defrost every 40mins is quite a lot, but not so far out that it would make such a big difference if your heat pump is as oversized as you say it is.
Noted.  Can you check what the heat pump itself thinks TWI and TWO are in the defrost and non defrost condition and also what the heat pump thinks its target temperature is in the defrost condition.  This info plus what happens tonight should help narrow down whether the assumption is correct or whether there is something else going on.
PS Hitachi call low noise mode 'night shift'
This post was modified 3 months ago 3 times by JamesPa
trebor12345
(@trebor12345)
2024 build bungalow
Southern england
179 m2
Underfloor heating
7KW heat pump
3.6KW solar panels
should have read "but the evidence isn't entirely consistent with that:"
trebor12345
(@trebor12345)
Heating only just going on today (4:30pm), been off since last night (my intervention as we are too hot).  Outside it's 13C here. Only reason for putting on tonight is to keep some heat in the floor. Bungalow at 21C, so not really cold.
I know about night shift.  Hitachi set this up when they updated the sw.  It was done to lower the output of the heat pump because it was oversized.
Regarding Twi and Two they match my probe data, but I will send the evidence from tonight.  (only in non-defrost mode as no defrosts tonight).
2024 build bungalow
Southern england
179 m2
Underfloor heating
7KW heat pump
3.6KW solar panels
Thanks.  Are you saying night shift is 'on'.  If so what are the parameters for it?
trebor12345
(@trebor12345)
@jamespa
I have not been in that area before, not my area of comfort, (don't like playing in case I break something.  Will have a look.
2024 build bungalow
Southern england
179 m2
Underfloor heating
7KW heat pump
3.6KW solar panels
trebor12345
(@trebor12345)
From the Display and my temp probes.  HP is in start up, been on for about 30 mins.
IMG 0454
Left: Twi. Middle: Two. Right: Return from underfloor
IMG 0455 2 2
This post was modified 3 months ago by trebor12345
2024 build bungalow
Southern england
179 m2
Underfloor heating
7KW heat pump
3.6KW solar panels
trebor12345
(@trebor12345)
I know these surveys are not the most accurate.
From the Energy Performance Report
Screenshot 2025 11 27 at 16.48.05
From the Energy Survey
Screenshot 2025 11 27 at 16.51.09
The building is incredible in mild conditions, such as today, no heating on.  But in very cold conditions (-4C) it seems to struggle (12kw overnight at AOT -4C), but that could be down to the inefficient defrost cycles.
I should add we have heat recovery running at the time, which is worth a loss of 500 Watts.
Just some observations above.
2024 build bungalow
Southern england
179 m2
Underfloor heating
7KW heat pump
3.6KW solar panels
@jamespa
No need to change anything, just to capture current values.  Without this information we literally don't know what we are dealing with!
trebor12345
(@trebor12345)
Yes its on at 80%.
2024 build bungalow
Southern england
179 m2
Underfloor heating
7KW heat pump
3.6KW solar panels
Page 5 / 14
